Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1344 討論
License file not recognized for questasim - Quartus 22.1.1 on Ubuntu 18.04
Dor_ian
初學者
3,203 檢視
I have some trouble with my license Questasim generated by SSLC.
I use last version for linux (Quartus and Questa 22.1.1) .
I set up my license variable LM_LICENSE_FILE correctly but when I try to lunch ./vsim (questa) on terminal I have an error message, or when I try to lunch  license setup on Quartus,  nothing is recognized.
I really have many issues to implement my architecture using linux and Quartus.
Thank you,
Dorian
0 積分
5 回應
AR_A_Intel
員工
3,164 檢視
Hello
Welcome to Intel forum. But before setting up Questa, would you kindly help check, whether your machine is supported or not (OS) by referring to link below:
https://www.altera.com/support/support-resources/download/os-support.html
after that could you help re-confirm the Questa setup referring here          https://www.intel.com/content/www/us/en/docs/programmable/683472/21-4/specifying-the-license-for-the-software.html
Dor_ian
初學者
3,111 檢視
Thanks for reply.
I have Ubuntu 18.04.6 LTS so I think it's not supported refering to you table, but I installed Questa Starter edition which is not in it. So is it supported ?
If not, what can be the solution on this version of Ubuntu to have a complete simulation tool with Quartus 22.1.1 ?
Dorian
Dor_ian
初學者
2,950 檢視
I checked the license.dat I have generated with SSLC and I found that there is just a INCREMENT field decommented and no FEATURE field as I found here : https://cdrdv2-public.intel.com/666293/quartus_install-683472-666293.pdf part 5.2.3.
I have just :
INCREMENT intelqsimstarter mgcld 2024.01 24-may-2024 uncounted \
Maybe that can explain the error I facing through.
When I try to regenerate a license file, I have now 2 INCREMENT field without FEATURE field.
It still doesn't work.
Dorian
AR_A_Intel
員工
2,883 檢視
We PM you another private message. Hope you received it.
AR_A_Intel
員工
2,827 檢視
We have not heard from you and I hope that my last note in private message mail clears up this matter and it can now be move forward. I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
回覆
