Hello.
I just installed Quartus Prime Lite 23.1 with the free version of questa.I've alos requested a free license. But while running the simulation it stopped with this message
e:/quartusprime/questa_fe/win64//vsim -c -do XOR_gate.do
Unable to checkout a license. Make sure your license file environment variable (SALT_LICENSE_SERVER, MGLS_LICENSE_FILE, LM_LICENSE_FILE)
is set correctly and then run 'lmutil lmdiag' to diagnose the problem.
Unable to checkout a license. Vsim is closing.
I've already checked my enviroment variable and diagnosed with command 'lmutil lmdiag', which returns this:
"intelqsimstarter" v2025.04, vendor: mgcld, expiry: 05-apr-2025
vendor_string: 96C88B25
uncounted nodelocked license, locked to ethernet address "b03cdc25a936" starts: 5-apr-2024, expires: 05-apr-2025
This is the correct node for this node-locked license
Enter <CR> to continue: CR
My system is Windows 11 23H2
I would appreciate it if anyone can help me with this.
Hi TonyWu-21474 ,
This error usually occurs when using a version of Questa that is not supported by the license that you have. Please confirm if your trying to use the Questa starter edition, Questa Intel FPGA Edition, QuestaSim, etc.
You could also try re-installling Questa
![](/skins/images/318B71AC6E18CAB8E2CA944B2397E849/responsive_peak/images/icon_anonymous_message.png)
