Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
NiosII debug issue
BJian12
Partner
Our quartus version is 19.3. The work frequency of Nios is 300M Hz. If we want to debug nios software, we need to change the default settings.
Nios 2->BSP->Editor->Settings->Advanced->hal->linker, then uncheck"allow_code_at_reset" and "enable_alt_load".
After the setting modification is finnished, re-build project and debug it as Nios 2 hardware. Then the software always shows a prompt that connected system ID has not found on target at expected base address. Please help to give some possible reason for that. ​
MEIYAN_L_Intel
Could you provide the full error message shown when re-build the project?
