- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Our quartus version is 19.3. The work frequency of Nios is 300M Hz. If we want to debug nios software, we need to change the default settings.
Nios 2->BSP->Editor->Settings->Advanced->hal->linker, then uncheck"allow_code_at_reset" and "enable_alt_load".
After the setting modification is finnished, re-build project and debug it as Nios 2 hardware. Then the software always shows a prompt that connected system ID has not found on target at expected base address. Please help to give some possible reason for that.
링크가 복사됨
1 응답
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Could you provide the full error message shown when re-build the project?
