Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1342 Discussions
Quartus 13.0sp1 missing devices after installation
AP11
It seems i've encountered the same issue as mentioned in both of these posts:
- community.intel.com/t5/Intel-Quartus-Prime-Software/Quartus-13-1-0-Stratix-3/m-p/1499311#M79048
- community.intel.com/t5/Intel-FPGA-Software-Installation/Want-Quartus-2-software-for-Altera-Stratix-3-FPGA-development/m-p/1627078#M6082
To summarize, after downloading and installing the Quartus v13 software package from the following page https://www.intel.com/content/www/us/en/software-kit/711920/intel-quartus-ii-subscription-edition-design-software-version-13-0sp1-for-windows.html
along with the .tar that "Includes all devices except Intel® Arria® series", i'm missing the stratix device files when trying to create a project.
However, device installer tells me this family has already been installed. I find it strange that the other devices do appear on project wizard but not the Stratix. How to solve this? perhaps there's a problem with the .qdz file?
Additional information:
- Whenever i open Quartus, i'm always asked if i have a licence, which i do and point to its location.
- I've already tried downloading the individual files, and installing them through the device installer which ended up in the same result (see images above)
I'd appreciate if you could point me to the right direction on how to solve this issue. Thanks!
AP11
I've tried the different troubleshooting steps mentioned above and unfortunately none of them seemed to work for me.
When I was about to give up, i decided to reinstall everything from scratch and install again, this time around using the .iso files and that seem to do the trick!
Here are the steps i followed (just in case someone might find this helpfull) which include part of the suggestions made by Richard.
1.  Uninstall everything, making sure there is no residue file in the installation directory.
2. Restarted my computer
3. Downloaded Quartus .iso file, verified Checksum was ok and install it using administrator privileges.
4. Downloaded Quartus devices1 .iso file, verified Checksum was ok and install it using administrator privileges.
    Note. I used the DeviceInstall.exe from the Quartus devices1 .iso.
5.  Checked by creating new project with wizard and scrolling down on the familiy tab
All in all, thank you for your quick reply and troubleshooting steps!
Hopefully, this thread will be helpful to someone else in the future.
RichardTanSY_Altera
This seems like a bad installation.
Here are troubleshooting steps that you may check:
1. Try restarting Quartus and your computer. This can help clear any temporary issues that may be causing the error.
2. Check your system resources, including memory, CPU usage, and disk space. Make sure you have enough available resources to run Quartus.
3. Try disabling any antivirus or firewall software temporarily, as they may be interfering with Quartus.
4. Install with Administrator privileges.
5. After uninstall, make sure there is no residue file in the installation directory.
6 If install using .tar, try to re-download the Quartus .tar installation package and install again. Check that the installation files .tar is not corrupted by checking the checksum.
For the license, you can try to specify the license file location by using the LM_LICENSE_FILE environment variable.
setx LM_LICENSE_FILE <path_to_license_file>;%LM_LICENSE_FILE%
For example: setx LM_LICENSE_FILE C:\intelFPGA\license.dat;%LM_LICENSE_FILE%
Richard Tan
HubertG
Hi AP11,
May I know is the workaround provided fixed your problem ?
Best Regards
Hubert
AP11
HubertG
Hi AP11,
That's Great ! Glad you have found your way out and thanks for being with us trying different way of troubleshooting and eventually got the solution ^-^ Congratulations !
Beyond this, is there any support that needed from our end ?
Best Regards
Hubert
AP11
Hi Hubert,
Thanks! I don't need further support.
As a side note, I keep being asked about the license location everytime i open Quartus, even though environmment variable is set. But, as this does not seem to be interfering with any other functionality it's fine. I believe thread can be closed.
HubertG
Hi AP11,
You are most welcome ^-^
Thanks for letting us know the configuration issue
Have A Great Day Ahead
Hubert
HubertG
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
