Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
QuestaSim Error
Akhil_Jain
      I believe that I tried running QuestaSim and got a Fatal License Error that says the following or something like that following: "Unable to checkout a license. Make sure your license file environment variable (e.g., LM_LICENSE_FILE) is set correctly and then run 'lmultil lmdiag' to diagnose the problem."
      I was able to download a license file for Questa Simulator and put into Quartus Prime Lite Edition's License Setup the file path to the license file for Questa Simulator. What steps do I need to take? Where should the license file be saved?
Akhil_Jain
AR_A_Intel,
      Hi. I created an "LM_LICENSE_FILE" variable with a value of a file path to a license file. Afterwards, I power cycled my Windows laptop. Afterwards, I was able to run QuestaSim.
      Let me know about whether you want me to do any actions.
Respectfully,
Akhil Jain
AR_A_Intel
Hello
Welcome to INTEL forum. Kindly provide your Questa license.dat file for further checking.
1) Error message screen shot
2) Machine OS information
3) Quartus version used
For privacy, reply/attach file in private message
Akhil_Jain
AR_A_Intel,
Respectfully,
Akhil Jain
KK181
Works for me after creating the "LM_LICENSE_FILE" variable
SDunc1
Interesting.  is that only for a localized license file?
For network licenses, is the System Environment variable "MGLS_LICENSE_FILE" still the correct one to use?
Source:  https://www.intel.com/content/www/us/en/docs/programmable/683472/21-4/specifying-the-license-for-the-software.html
AR_A_Intel
Sounds good, thanks for sharing and hope everything is working well at your side. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
pragathi
Akhil_Jain
      Do you still have a question?
Respectfully,
Akhil Jain
prashansha
Ya can you please tell me what to do ?
Akhil_Jain
      I can try to help. I think that there were multiple Intel webpages' steps to follow that I used. I do not remember all the steps I did. I think that I had to create a license file and download it and then restart my computer. Also, as I wrote on this webpage, "I created an 'LM_LICENSE_FILE' variable with a value of a file path to a license file. Afterwards, I power cycled my Windows laptop. Afterwards, I was able to run QuestaSim."
      See if any information on the webpage at the following link helps: https://community.intel.com/t5/Intel-FPGA-Software-Installation/Intel-Starter-Edition-2021-2-requires-License/td-p/1280757. The webpage might be outdated.
      Let me know what you do and whether you need additional help.
Respectfully,
Akhil Jain
prashansha
did your issue get resolved? iam getting same problem can u plz help
Akhil_Jain
      I got my issue resolved. I might be able to help.
Respectfully,
Akhil Jain
