Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1342 Discussions
Set_output_delay commands does not apply to the output signal
JOter
We have a design where we control an external RAM memory. We generate the CLK and control memory signals in a FPGA (Cyclone IV). The CLK signal is generated using a PLL, with 180º phase shift.
The design is working but we have detected that "set_output_delay" dosen't apply. For example, we have compared, in an oscilloscope, the delay beetwen the signals CLK and a bit ADD[15] bus and it is constant for any "set_out_delay".
We are using the next constrains configuration:
create_clock -name RAM_CLK -period 16 [get_ports {RAM_CLK}]
create_generated_clock -name vt_RAM_CLK -source [get_ports {RAM_CLK}] -divide_by 1 -multiply_by 1 -phase 180
set_output_delay -clock {vt_RAM_CLK} 3 [get_ports {RAM_ADD[15] }].
In next figure, you can see timing of both signals.
The delay is contant for any "output_delay" value (0, 1, 2, 3..).
KhaiChein_Y_Intel
The delay is the same becuase the register is located in the I/O. The dalay from the register to the port is the same. Do you see timing violation when you set the output delay value to 12 and higher? If you move this register out of the I/O, you will see some differences in your oscilloscope.
JOter
Thanks. I was confused with some terms.
KhaiChein_Y_Intel
You are welcome.
