Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1337 Discussions
Unable to launch license manager as a service
CBlow
Partner
My customer is able to start the license server interactively, but this requires a user to stay logged onto the server for the licenses to be available. He wants to launch as a service, but it errors as shown below.
Any suggestions?
Status
Flexible License Manager status on Wed 10/9/2019 13:35
[Detecting lmgrd processes...]
License server status: 28001@****-******
   License file(s) on ****-******: C:\Intel\License\License.dat:
lmgrd is not running: Cannot connect to license server system.
The license server manager (lmgrd) has not been started yet,
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Server name:  xx.xx.xxx.xx
License path: 28001@****-******;
FlexNet Licensing error:-15,10. System Error: 10061 "WinSock: Connection refused"
AR_A_Intel
Hello
Welcome to INTEL forum. Could you help check connection to server? But before setting up your license, would you kindly help check whether your machine is supported or not (OS) by referring to ling below:
https://www.altera.com/support/support-resources/download/os-support.html
Make sure the port used by license server or vendor daemon is not blocked. The port number is required for Windows systems and should be outside of the 27000-28000 range and be unique on the machine. The following example shows how to specify port numbers in a floating license file. example, specify ports 1800, 1801, and 1802.
SERVER myServer 0123456789ab 1800
VENDOR alterad ./alterad port=1801
VENDOR mgcld ./mgcld port=1802
My suggestion would be:
1)     After VPN connection is established, setup license path in Quartus II>>tools>>license setup.
2)     Verify license server is running by using “lmutil lmstat –a –c <port>@<server> in BOTH server and client machine.
3)      Ping license server via VPN or telnet <host>< port> to check the TCP connection is established
Please stop and restart the server. You need to allow the firewall access to the port number from both server and client machine.
You can also refer to link below for more detailed instructions for Setting up a floating network license server (page 37 of 59):
https://www.altera.com/content/dam/altera-www/global/en_US/pdfs/literature/manual/quartus_install.pdf
You can also refer this following YouTube for license setup. https://www.youtube.com/watch?v=Ob9ei5lMgG
You can also refer to this following YouTube on Setting up and debugging Quartus floating licenses.
https://www.youtube.com/watch?v=llLaWatUbe8
Let me know if this information is helpful.
CBlow
Partner
Here are the results from the server, he is unable to get them from the client since lmtools is not installed.
Please note the license is working as expected when launched from the command line, the problem is when running as a service.
C:\Intel>lmutil.exe lmstat -a -c 28001@xxxx-xxxx16
lmutil - Copyright (c) 1989-2014 Flexera Software LLC. All Rights Reserved.
Flexible License Manager status on Wed 10/16/2019 08:54
License server status: 28001@xxxx-xxxx16
   License file(s) on xxxx-xxxx16: c:\intel\license\license.dat:
xxxx-xxxx16: license server UP (MASTER) v11.13.0
Vendor daemon status (on xxxx-xxxx16):
  alterad: UP v11.16.2
Feature usage info:
Users of ip_base: (Total of 1 license issued; Total of 0 licenses in use)
Users of maxplus2: (Total of 1 license issued; Total of 0 licenses in use)
Users of maxplus2verilog: (Total of 1 license issued; Total of 0 licenses in use)
Users of maxplus2vhdl: (Total of 1 license issued; Total of 0 licenses in use)
Users of quartus_nonvolatile_encryption: (Total of 1 license issued; Total of 0 licenses in use)
Users of quartus: (Total of 1 license issued; Total of 0 licenses in use)
Users of 6AF7_00D8: (Total of 1 license issued; Total of 0 licenses in use)
Users of 6AF7_0014: (Total of 1 license issued; Total of 0 licenses in use)
Users of 6AF7_0034: (Total of 1 license issued; Total of 0 licenses in use)
    mgcld: UP v11.13.1
Feature usage info:
Users of mgcvipae: (Total of 1 license issued; Total of 0 licenses in use)
Users of mgcvipaeaxi: (Total of 2 licenses issued; Total of 0 licenses in use)
Users of mgcvipaeaxi4: (Total of 1 license issued; Total of 0 licenses in use)
AR_A_Intel
Hi
To narrow down this issue. Can you provide your
1) Debug.log file
3) Error message screen shot
5) Machine OS information
6) Quartus version used
7) License.dat file
And for privacy, you can also reply/attach your file in private message.
CBlow
Partner
can you send me a link for a private message?
thanks,
Carl
AR_A_Intel
We have PM you a message. Thanks
