Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
Audio Codec IP core UP
I'm trying to use the audio core with the Nios IDE. Well, i think that i had no problems to link the libraries for the nios IDE. My problem is when i use the functions of the core.
My code do this:
- First i open the device with alt_up_audio_open_dev. The datasheet mention that the parameter of this function use only the name in the SOPC builder but it doesn't compile. So I check the system.h and found that the audio module is named# define AUDIO_0_NAME.
- Now I read read the fifo with the function : alt_up_audio_read_fifo. I add some code to print the return of this function. The first time it return the number of words that i put in the function, but when i reset the system, it only read 2 or 1 word from the fifo.
Maybe someone can help me with this.
I am sorry but i cant help you because i am stacked in the same spot!!! If you manage to make it work please post your version....or email me ok? If i find something i will do the same.
thanks a lot
fasmatikos
