Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
Audio IP Core Help
I am in the process of attempting to use the Audio IP Core to take input from the Mic, and then output it the Line out.
I have created a system in the SOPC builder with the following components:
cpu_0
onchip_memory2_0
PIO(Input)
PIO(Output)
audio_and_video_config_0
audio_0
For the audio_and_video_config_0, I've set it to initialize both Audio and Video. I've set the In path to Microphone to ADC, and Out to enable DAC.
This will build without error.
I have the following C application to run on this system just to verify the Audio I/O is working.
# include <system.h># include <altera_up_avalon_audio.h>
# define Switches (volatile char *) SWITCHES_BASE# define LEDs (char *) LEDS_BASE
# define BUFFER_SIZE 512
void increaseGain(unsigned int *buffer, unsigned length);
int main()
alt_up_audio_dev * audioDev = 0;
unsigned int buffer[BUFFER_SIZE];
unsigned length = (BUFFER_SIZE/2);
int readData = 0;
//Open the Audio device
audioDev = alt_up_audio_open_dev(AUDIO_0_NAME);
//reset the Audio Device
alt_up_audio_reset_audio_core(audioDev);
while (1)
*LEDs = *Switches;
readData = alt_up_audio_read_fifo(audioDev, buffer, length, ALT_UP_AUDIO_LEFT);
alt_up_audio_write_fifo(audioDev, buffer, readData, ALT_UP_AUDIO_LEFT);
readData = alt_up_audio_read_fifo(audioDev, buffer, length, ALT_UP_AUDIO_RIGHT);
alt_up_audio_write_fifo(audioDev, buffer, readData, ALT_UP_AUDIO_RIGHT);
return 0;
Right now when I download my image, the mic in, is automatically playing out the Line out, however it's very quiet and distorted.
Any assistance is appreciated.
hi!
i m sorry i cannot answer your question, but can i thinku can help me as i m working on a similar project...
where should i copy the header file to avoid the long include statement like "c:\dir1\dir2\include\altera_up_avalon_audio.h
or is it possible to do the same in NIOS2 IDE somehow?
