Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1238 Discussions
Building serial communication...
I am using a FLEX10K UP2 board and want to do some image processing on it. I would like to build an 8-bit internal RAM for my FPGA in order for my design file to write data to the RAM and read data from my CPU. I have been advised to use the serial communication to achieve data interaction between my CPU and FPGA. Since I am a beginner here, my questions would be:
  • Any suggestion on creating internal RAM? By using and altsyncram and associate it to my design file?
  • If so, then how to establish a serial commucation between my CPU and then internal RAM? Is SOPC Builder useful here? In the mean time, I have done some reading on UART, RS232, parallel-in-serial-out register and serial-in-parallel-out register.
I really appreciate for any references related to above issues.
Due to the limited LE capacity of Flex10k, SOPC wouldn't be a good idea.
Regarding simple UART reference designs. Did you notice the projects from opencores, e.g.:
http://www.opencores.org/projects.cgi/web/uart/overview
If you don’t stick to serial communication, you can use In-System Sources and
Probes to read and write a FPGA internal RAM.
http://www.altera.com/literature/hb/qts/qts_qii53021.pdf
This tool provides a kind of parallel I/O ports resident in your FPGA. You can control the I/O ports through a JTAG cable and a TCL script.
Basically a good suggestion, but not helpful wit Flex10k.
I don’t aware that the IP does not support Flex10k. Thanks for the correction.
I also nearly forgot, that there have been FPGA without SignalTap, Memory Content Editor and all these functions depending on virtual JTAG. I knew with Flex10k from a preceeding topic.
Thanks for all the advice. I now studying the design reference as provided in Opencores.org.
But how do SignalTap, Memory Content Editor and all these functions affect my UART design?
Thanks!!!
The said tools don't affect your design, cause they aren't available with Flex10K. Would be interesting tools otherwise.
If it helps I can send you my own UART IPcore. I wrote it for one of my projects. It requires 50 MHz clock signal and has user-set baudrate from 150 to 38400 bps. Write me an e-mail if you will need it (zaquadnik@gmail.com).
