Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1237 Discussions
Could not query JTAG Instance IDs. Please ensure the FPGA has been configured using the correct .sof
RainFlash
-----INTEL FPGA MONITOR PROGRAM  18.1------
INFO&ERRORS
Writing the makefile: C:/surum18icin/makefile
cd C:/surum18icin/; make clean
make: *** No rule to make target 'clean'. Stop.
C:/intelFPGA_lite/18.1/quartus/bin64/quartus_pgm -c "USB-Blaster [USB-0]" --auto
1) USB-Blaster [USB-0]
031050DD 10M50DA(.|ES)/10M50DC
Info: *******************************************************************
Info: Running Quartus Prime Programmer
Info: Version 18.1.0 Build 625 09/12/2018 SJ Lite Edition
Info: Copyright (C) 2018 Intel Corporation. All rights reserved.
Info: Your use of Intel Corporation's design tools, logic functions
Info: and other software and tools, and its AMPP partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Intel Program License
Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
Info: the Intel FPGA IP License Agreement, or other applicable license
Info: agreement, including, without limitation, that your use is for
Info: the sole purpose of programming logic devices manufactured by
Info: Intel and sold by Intel or its authorized distributors. Please
Info: refer to the applicable agreement for further details.
Info: Processing started: Tue Aug 20 15:46:18 2024
Info: Command: quartus_pgm -c "USB-Blaster [USB-0]" -m jtag -o P;C:/intelFPGA_lite/18.1/University_Program/Computer_Systems/DE10-Lite/DE10-Lite_Computer/verilog/DE10_Lite_Computer.sof@1
Info (213045): Using programming cable "USB-Blaster [USB-0]"
Info (213011): Using programming file C:/intelFPGA_lite/18.1/University_Program/Computer_Systems/DE10-Lite/DE10-Lite_Computer/verilog/DE10_Lite_Computer.sof with checksum 0x0155F818 for device 10M50DAF484C6GES@1
Info (209060): Started Programmer operation at Tue Aug 20 15:46:21 2024
Info (209016): Configuring device index 1
Info (209017): Device 1 contains JTAG ID code 0x031050DD
Info (209007): Configuration succeeded -- 1 device(s) configured
Info (209011): Successfully performed operation(s)
Info (209061): Ended Programmer operation at Tue Aug 20 15:46:24 2024
Info: Quartus Prime Programmer was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 4429 megabytes
Info: Processing ended: Tue Aug 20 15:46:24 2024
Info: Elapsed time: 00:00:06
Info: Total CPU time (on all processors): 00:00:07
cd C:/surum18icin/; make compile
make: *** No rule to make target 'compile'. Stop.
Please ensure the FPGA has been configured using the correct .sof file.
ERROR
"Could not query JTAG Instance IDs.
Please ensure the FPGA has been configured using the correct .sof file."
pleas help me what should i do
Since I was having problems with 21.1, I downloaded the old version and encountered problems with it too.
-----INTEL FPGA MONITOR PROGRAM  21.1------
nios2-elf-as.exe --gstabs -I "C:/intelFPGA_lite/21.1/nios2eds/components/altera_nios2/sdk/inc/" getting_started.s -o getting_started.s.o
/bin/sh: 1: nios2-elf-as.exe: not found
make: *** [amp.mk:79: getting_started.s.o] Error 127
I am also getting this error in 21.1. Can you fix one of my two errors? The errors have worn me out a lot.
Labels (2)
RainFlash
I gave up on 18.1 and tried 21.1 again. It was fixed. I am leaving a YouTube link for those who may have similar problems. https://www.youtube.com/watch?v=r8dz3H1qzh0
I'll keep the post open for the 21.1's error
Fakhrul
Hi RainFlash,
We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
