Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1235 Discussions
[DE2-Help] Putting WAVE files in SRAM or FLASH, then playing them through speakers?
Hey Everyone,
My second hot topic is how to playback say a WAVE file through the DE2 board. I know that this is demonstrated in some of the examples that came with the board but they are much more complicated then what I would like to do. I just need to play back 2/3 sound files at certain states, and I do not want to use NIOS (so no SD card driver etc.) The goal is a pure hardware implementation. If anyone could explain/show some simple sample code that would be awesome.
Pachu
Pachu.
Seems that you have the same "questions"-"ideas" as me.
You wont use the NIOS II to do the task, but I think wouldn't be a simple way to do it in pure hardware code. Instead maybe using NIOS would be more simple.
In fact you need to save to SD card, "the sounds", and write a driver for the audio codec, and SD card.
Also I would like too, to hear some "guru" opinion about this here.
