Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
Using LCD on DE2
Hi. I know a lot of post are about lcd and de2 but i have some problems.
In fact, i use the 3 files in my project:
altera_avalon_lcd_16207.c
altera_avalon_lcd_16207.h
altera_avalon_lcd_16207_regs.h
(i have attached them in txt so you can check it).
The problem is: I'm not very good at c language and I was wondering if someone can write me a small code that uses functions of altera_avalon_lcd_16207.c to control the LCD.
PS: I use a NIOSII and NIOS IDE
Hi.
In "DE2_demonstrations\DE2_NET\hello_led_0" look for LCD.C file. There you have an example.
It's:
--- Quote Start ---
void LCD_Test()
char Text1[16] = "Altera DE2 Board";
char Text2[16] = "Ethernet Testing";
// Initial LCD
LCD_Init();
// Show Text to LCD
LCD_Show_Text(Text1); //This show the above text 1st line
// Change Line2
LCD_Line2();
// Show Text to LCD
LCD_Show_Text(Text2); //This show the above text 2nd line
--- Quote End ---
