Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1238 Discussions
DE2 cannot open a file in the SD card
The function alt_up_sd_card_find_first works perfectly, which can help me print out all the file names in the SD card. (So I think it's not any formatting and size problem of the SD card. It's 2GB and FAT16 anyways.)
But when I call alt_up_sd_card_fopen, it returns me -1, so I can't open, create, and write a file.
Below is my simple code of creating a text file, and print out all the file names:
alt_up_sd_card_dev *device_reference = NULL;
int connected = 0;
char* fileName;
device_reference = alt_up_sd_card_open_dev(SD_CARD_NAME);
short int handler;
char buffer[10000] = "Testing Testing\0";
int index = 0;
if (device_reference != NULL) {
handler = alt_up_sd_card_fopen("test2.txt", false);
if (handler >= 0){
while (buffer[index] != '\0'){
alt_up_sd_card_write(handler, buffer[index]); index++;}
alt_up_sd_card_fclose(handler);
else printf("cannot open file: %d\n",handler);
while (1) {
if ((connected == 0) && (alt_up_sd_card_is_Present())) {
printf("Card connected. \n");
printf("fat16: %d",alt_up_sd_card_is_FAT16());
if (alt_up_sd_card_is_FAT16()) {
printf("FAT16 file system detected. \n");
if(alt_up_sd_card_find_first("",fileName)==0){
printf("Files detected: \n");
do{
printf("%s \n",fileName);
}while(alt_up_sd_card_find_next(fileName)==0);
else if (alt_up_sd_card_find_first("",fileName)== -1)
printf("No files. \n");
} else {
printf("Unknown file system. \n");
connected = 1;
} else if ((connected == 1) && (alt_up_sd_card_is_Present()
== false)) {
printf("Card disconnected. \n");
connected = 0;
I found a similar thread about this issue.
http://www.alteraforum.com/forum/showthread.php?t=34101
But I had the interface already... I don't know why it's still nothing changes???
Please help, thanks
