Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1238 Discussions
Decimal Point on Seven Segment Display for DE2-115
Hi everyone,
On the DE2-115 development board's 8 7-segment-displays, there are decimal points. There are, however, no FPGA pin numbers to access these decimal points--at least I can't find them when looking at pages 37-39 of the DE2_115_User_manual.pdf
Does anyone using this board know if it is possible to turn the decimal points on the seven-segment-displays on and off?
Thanks very much,
Nate
The decimal points aren't connected on the DE2-115 board. You should be able to find cheap 7 segment displays on ebay or amazon that have a decimal point.
Tirdad
What about the common anodes? Are any pins connected to the anode?
I want to control the seven-segment display (turn it on and off), but I can't seem to find the pin assignments.
Nicholas66
To enable the decimal point on the seven-segment display for the DE2-115, you need to check the control signal associated with the DP (decimal point) segment. Make sure your FPGA design includes it in the output mapping. Are you using Verilog or VHDL for implementation?
FvM
@Tirdad: DE2-115 schematic clarifies the question. Anodes are tied to 2V5 supply. Blanking the display can be done by logic in segment outputs.
@Nicholas66: The question was answered 9 years ago. DP is unconnected on this dev board.
