Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1238 Discussions
Did I need to set a proper pin assignment if I running a simulation ?
fpga_nick
I am trying to run a design example simulation for AGIB027R29A1E2VR3, F-tile.
Quartus version v23.3 , Questasim 2023-2.
But the target devkit with proper pin selection only available for F-series devkit - non I-series devkit. If I select F-series devkit, the simulation run well.
While I select "NONE" as my device is targeted  AGIB027R29A1E2VR3, the simulation fail in "ld_debug".
Question -
  1. Did I need to set a proper pin assignment if I running a simulation ?
  2. If the answer is YES in first question, Can I use the .qsf pin mapping from F-series F-tile and plug directly I-series F-tile ?
Labels (2)
Wincent_Altera
For running simulation, pin assignment is not required, but you may need to run synthesis.
Using your environment I am able to run the simulation passing the ld_debug.
Please check back the step, Normally the fail will occurs if your host is out of memory, the full simulation of "run -all" normally took few GBs on the memory space, I suggest to try clear the memory before re-run
Wincent_Altera
fpga_nick
I try , no2 where I use the .qsf from F-series F-tile , plug in to I-series F-tile.
BUT the compilation fail . appreciate if someone can help to advise
ShengN_Intel
May I know which design example and document you're following?
Sheng
fpga_nick
Agilex I-series ES device targeted F-tile Avalon Streaming Example Design.
Wincent_Altera
Wincent_Altera
fpga_nick
