Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
EPCQ Programming Issue
Stevendsmith
We are using a Cyclone IV FPGA with an EPCQ16 Serial Configuration Device. We are programming the EPCQ through the FPGA using JTAG and USB Blaster II. We were able to successfully program the EPCS on an earlier version board:
This is what success looks like with an EPCS16 device targeted and the exact same source bitstream...
Info (209060): Started Programmer operation at Fri Apr 09 19:52:26 2021
Info (209016): Configuring device index 1
Info (209017): Device 1 contains JTAG ID code 0x020F10DD
Info (209007): Configuration succeeded -- 1 device(s) configured
Info (209018): Device 1 silicon ID is 0x14
Info (209044): Erasing ASP configuration device(s)
Info (209023): Programming device(s)
Info (209011): Successfully performed operation(s)
Info (209061): Ended Programmer operation at Fri Apr 09 19:52:51 2021
EPCQ16AS18N
Failed Programming
Info (209060): Started Programmer operation at Fri Apr 09 19:46:41 2021
Error (209025): Can't recognize silicon ID for device 1. A device's silicon ID is different from its JTAG ID. Verify that all cables are securely connected, select a different device, or check the power on the target system. Make sure the device pins are connected and configured correctly.
Error (209012): Operation failed
Info (209061): Ended Programmer operation at Fri Apr 09 19:46:43 2021
PCB, pin out, MSEL pins, all to spec...
Thanks for your help!
Ash_R_Intel
Hi Steven,
Please provide more details:
1) Are you trying two different devices, EPCQ16 and EPCS16 using same programming file?
2) What is the type of programming file you are using?
3) Quartus version?
4) Other than JTAG, do you have other configuration method on board?
Regards.
Ash_R_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
