Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1238 Discussions
HPS FPGA UARTs Mapping Change
EFroh
The HPS FPGA UARTs are automatic mapped in the 'build tree'- one to Linux kernel, and other to u-boot.
How do I map one UART to both?
FawazJ_Altera
Can you elaborate more about your question?
Is this the HPS UART? Are you going to use this UART for serial terminal or data communication?
Thank you
EFroh
There is one UART that works right on the board.
I have an Arria 10 HPS processor that communicates with different peripherals..
I want to use this UART for the u-boot and the Linux both, for CPU stdio interface (serial terminal communication).
But the UART 0 is mapped to the Linux and UART 1 is mapped to the u-boot.
I tried to enable 2 or 1 UARTs on the Pin MUX peripherals GUI , but that didn't solve the problem,
when I enabled one UART, the u-boot UART is disabled from the build tree mapping. and only Linux UART is works
Can you please help me with it?
EFroh
I attached a snapshot.
FawazJ_Altera
I presume you are using the A10 SDMMC boot, with GHRD design. In GHRD design, UART is configured with dedicated IO. You can ensure same UART node configuration in both U-Boot device tree and Linux device tree., and serial0 is specified.
Example UART node configuration at U-Boot DTS
https://github.com/altera-opensource/u-boot-socfpga/blob/socfpga_v2019.10/arch/arm/dts/socfpga_arria10_socdk.dtsi
aliases {
       ethernet0 = &gmac0;
       serial0 = &uart1;
       i2c0 = &i2c1;
&uart1 {
    u-boot,dm-pre-reloc;
    status = "okay";
https://github.com/altera-opensource/u-boot-socfpga/blob/socfpga_v2019.10/arch/arm/dts/socfpga_arria10.dtsi
uart0: serial0@ffc02000 {
           compatible = "snps,dw-apb-uart";
           reg = <0xffc02000 0x100>;
           interrupts = <0 110 IRQ_TYPE_LEVEL_HIGH>;
           reg-shift = <2>;
           reg-io-width = <4>;
           clocks = <&l4_sp_clk>;
           resets = <&rst UART0_RESET>;
           status = "disabled";
       uart1: serial1@ffc02100 {
           reg = <0xffc02100 0x100>;
           interrupts = <0 111 IRQ_TYPE_LEVEL_HIGH>;
           reg-shift = <2>;
           reg-io-width = <4>;
           resets = <&rst UART1_RESET>;
