Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1238 Discussions
Help with Basic Concept Please
Hello folks, Having lots of trouble understanding a simple concept. I would like to know how the data register works for this UART. From the Data sheet, this is what info i have:
device
RS-232 UART
configuration
Two 32-bit mapped registers
input/output
Either
address base
0x10001010
address map
address
r/w
description
base
R/W
Data Register
23:16 - Number of characters available to read (after this read - see Notes)
15 - read data valid
9 - parity error
7:0 - the data itself
base+4
R/W
Control Register
23:16 - Spaces available for writing
9 - Write interrupt is pending
8 - Read interrupt is pending
1 - Enable write interrupts
0 - Enable read interrupts
Now a simple question, Let's say i want to read the UART of the Board, i wrote a short code in C for (Altera Monitor Program) but i get a garbage as input. Using a Terminal on PC to send some characters, and would like to display them on the HEX Disp. Here is what i tried to do:
mask = ((*RS232_UART_DATA)&0xFF00FF); // Reading the UART and masking some bits
HEX=mask; // Storing data to be written to hex
The issue is before i even get to send a character from the PC side, i start seeing garbage on HEX. And when i do attempt to send a character, the HEX shows more garbage. At least i can be sure the data is being transmitted, but i have no knowledge on how to mask the DATA Register appropriately. ANY HELP WOULD BE APPRECIATED!!!!
Assuming your baud rate, etc settings match between the PC and FPGA board, you need to check the data valid bit. You only have input data when that bit is set. If it isn't set, come back later and check again. If the data valid bit is set the number of characters field will tell you how many bytes you can read before waiting for data valid again. The code you have doesn't do this.
