- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
I'm trying to use the new Altera UP SD card IP core on my DE2 board, but having some problems. Has anyone got it working yet? I've installed the University Program package (altera_upds_setup.exe) along with Quartus and Nios 9.0 on my PC. Then I created a SoPC with the new SD card IP core in it and wired them up. (Nios CPU, On-chip mem, SDRAM, PLL, JTAG UART, LED RED, Altera_UP_SD) Then in Nios, I run something similar to the code in the documentation. I can see the correct 390KHz clock output using an oscilloscope, but it never reports that my card is inserted. Can anyone help me?int main()
unsigned int *aux_status_register = ((unsigned int *)(ALTERA_UP_SD_BASE + 564));
unsigned int status;
printf("Hello from Nios II!\n");
printf("Address of aux_status_register: 0x%08x\n", (unsigned int) aux_status_register);
do { // wait for SD card to be inserted
status = *aux_status_register;
printf("%d %d\n", status, *aux_status_register);
*LED_RED = status; // display status on the board
} while ((status & 0x02) == 0);
printf("SD card inserted.\n");
return 0;
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
What SD card IP core do you mean? I've not seen any such university IP core.
The SD card example for DE1 and DE2 boards are just a couple PIO's for the SD's DAT, DAT3, CMD and CLK lines. I've made my own SD card core which is more efficient. It will wait for the CPU to send a command, and then wait for the SD's response and data if needed in hardware. It's a pretty simple module, I've attached all the needed files to this thread if you need it. Hope you like it.- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
--- Quote Start --- ftp://ftp.altera.com/up/pub/university_program_ip_cores/90/sd_card_interface_for_sopc_builder.pdf ftp://ftp.altera.com/up/pub/university_program_ip_cores/90/altera_up_avalon_sd_card_interface.zip --- Quote End --- Yep, this is the one I'm working on. I got a partial workaround for this issue. It appears that the core does not work with all SD cards. I tried a Lexar Media SD card 128MB initially, which didn't work. But my Apacer and Nokia branded SD card works. SDHC cards don't work. Now I'm trying to get it working with the DMA controller to speed it up. kwuaker, thanks for sending me your core. What transfer rate did you get from your core?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
After a lot of trying I got the UP IP Finaly to work. But I have to say that it is a little bit Buggy and especially the Doku is bad.
1. The HAL Driver doesn't check the Valid Bit of the Aux Reg. You have to implement your own checking Function, otherwise you get random errors depending on the speed of your System and the Card. 2. HAL does not work on a NIOSII with Cache, because it access the Memory with Pointers instead of direct IOWR and IORD. 3. It is very slow. I got 140kB with direct access. (But I still checking this).- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi All,
You can try it SD Card IP core from SLS ( www.slscorp.com ) I think they will provide SD core for evaluation purpose. Using this you might be getting speed as per SD card specification mentioned. Regards, Hardik Sheht- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
HI Schaf,
I am working on the same IP core for SD card and it doesn't work at all. Can you send your code to me. It will be a great help from you, my mail ID is todakar_vivek@yahoo.com Thanks, Vivek.- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
--- Quote Start --- Hi All, You can try it SD Card IP core from SLS ( www.slscorp.com ) I think they will provide SD core for evaluation purpose. Using this you might be getting speed as per SD card specification mentioned. Regards, Hardik Sheht --- Quote End --- There's also another eval sd card reader ip core from El Camino: http://www.elcamino.de/prode.html
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
hey ppl,
I am having problem with using this Ip core from university program, i m running the same program given in the altera document for the sd_card ip core, but it is not detecting the card, am i missing out on something crucial here? i m a beginner thanks,- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi all!
I am working on DE2-115 Board. My purpose now is load the file.sof from SD Card to FPGA chip.The result is display on Led. have anyone done it? i am very glad to get your support, Thanks all. if possible, pls send me information to my email pavenpham@gmail.com- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
--- Quote Start --- What SD card IP core do you mean? I've not seen any such university IP core. The SD card example for DE1 and DE2 boards are just a couple PIO's for the SD's DAT, DAT3, CMD and CLK lines. I've made my own SD card core which is more efficient. It will wait for the CPU to send a command, and then wait for the SD's response and data if needed in hardware. It's a pretty simple module, I've attached all the needed files to this thread if you need it. Hope you like it. --- Quote End --- Hi, is it posssible create a file with your module??
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
i used the university sd card ip core, its working fine but have problem when writing data, i tried to write text file greater than 32kb but its getting corrupted, if i go less than that size, ip core is working fine. how to solve this..- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
--- Quote Start --- ftp://ftp.altera.com/up/pub/university_program_ip_cores/90/sd_card_interface_for_sopc_builder.pdf ftp://ftp.altera.com/up/pub/university_program_ip_cores/90/altera_up_avalon_sd_card_interface.zip --- Quote End --- I'm student and i'm working on this topic can you up this links ?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
how to use this code.. can you help me.. tnx
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi! I'm using De1-Soc development board. It has micro SD card which connected to the HPS. Can I use Altera University Program SD Card IP cores for that board. Can any one tell me is there have any way to access Micro SD card from FPGA.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Kwuaker,
Can i use sdcard file for detecting micro sdhc card?- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Under university program Altera provides IP and Altera _up_sd is one of them.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
--- Quote Start --- What SD card IP core do you mean? I've not seen any such university IP core. The SD card example for DE1 and DE2 boards are just a couple PIO's for the SD's DAT, DAT3, CMD and CLK lines. I've made my own SD card core which is more efficient. It will wait for the CPU to send a command, and then wait for the SD's response and data if needed in hardware. It's a pretty simple module, I've attached all the needed files to this thread if you need it. Hope you like it. --- Quote End --- Thanks for providing the IP for SD card. can I use this IP to store data also. I have VEEK-MT one of the Altera board. It has camera module attached with the board. I just want to store the images captured. It will be helpful if you guide or provide some documents.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
