Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1235 Discussions
Intel Fpga Monitor Program not open Editor Window tool
CARAM
I are doing the "intel fpga monitor program tutorial for ARM" for Quartus Prime 17.1
I have downloaded and installed the intel_fpga_upds_setup_v17.tar archive and quartus ii 17.1 suite.
My operating system is ubuntu 18.04 LTS
When i run the intel-fpga-monitor program in the Menu bar the windows menu have the Editor and Program Files menus with GREY CHARS.
When i do the simple.s tutorial with DE1-SoC-computer system i can edit the source assembly module simple.s
How can i do for correct install the monitor program? Again download the installer archive? Some setting up?
Thanks in advance
EBERLAZARE_I_Intel
Can you screenshot the bugged menus that you see?
Also, have you follow thoroughly the steps to install when using Linux operating system at section 2.2 Using a Linux Operating System?
CARAM
I have installed intel_fpga_upds_setup with the oficial instructions but i think that the system configuration of Ubuntu 18.04 (java virtual machine, jar compiler, etc) are not correct. These are the warning when i execute ./intel-fpga-monitor-program script:
University_Program/Monitor_Program/bin$ ./intel-fpga-monitor-program
Java HotSpot(TM) 64-Bit Server VM warning: You have loaded library /home/candido/flexdock/RubberBand.so which might have disabled stack guard. The VM will try to fix the stack guard now.
It's highly recommended that you fix the library with 'execstack -c <libfile>', or link it with '-z noexecstack'.
java.net.ConnectException: Conexión rehusada
   at java.net.PlainSocketImpl.socketConnect(Native Method)
   at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source)
   at java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source)
   at java.net.AbstractPlainSocketImpl.connect(Unknown Source)
   at java.net.SocksSocketImpl.connect(Unknown Source)
   at java.net.Socket.connect(Unknown Source)
   at java.net.Socket.<init>(Unknown Source)
   at org.flexdock.docking.drag.outline.x11.Connection.<init>(Connection.java:35)
   at org.flexdock.docking.drag.outline.x11.Graphics.create(Graphics.java:49)
   at org.flexdock.docking.drag.outline.x11.Graphics.<clinit>(Graphics.java:34)
   at org.flexdock.docking.drag.outline.x11.X11RubberBand.<clinit>(X11RubberBand.java:14)
   at java.lang.Class.forName0(Native Method)
   at java.lang.Class.forName(Unknown Source)
   at org.flexdock.util.Utilities.createInstance(Utilities.java:285)
   at org.flexdock.docking.drag.effects.EffectsManager.createRubberBand(EffectsManager.java:94)
   at org.flexdock.docking.drag.effects.EffectsManager.loadSystemRubberband(EffectsManager.java:137)
   at org.flexdock.docking.drag.effects.EffectsManager.prime(EffectsManager.java:43)
   at org.flexdock.docking.drag.effects.EffectsManager.<clinit>(EffectsManager.java:37)
   at org.flexdock.docking.drag.DragManager.prime(DragManager.java:42)
   at org.flexdock.docking.DockingManager.init(DockingManager.java:137)
   at org.flexdock.docking.DockingManager.<clinit>(DockingManager.java:127)
   at monitor.ui.UIManager.initDocking(UIManager.java:338)
   at monitor.ui.UIManager.init(UIManager.java:161)
   at monitor.globals.Globals.init(Globals.java:84)
   at monitor.Main.main(Main.java:38)
There is a warning because Rubberband.so is 32 bit library and de Java VM is 64 bit
I have attach the image of the interfaz with "Editor" and " Projects Files" menus not accesible.
Cándido
CARAM
Hi , there are some menu option that can the effect of activate editor "Edit -> Enable Source Level Debugging" and "Edit -> Extended -> Debug Info". Sometimes if it activate these options after Board connection and configuration the "Editor" and " Project Files". Kind Regards.
EBERLAZARE_I_Intel
From your latest reply, are you still seeing the "Editor" and "Project Files" tab un-clickable?
CARAM
No problem if i select first "Enable Source Level Debugging"
EBERLAZARE_I_Intel
Noted the information, are you facing any other issue in the tutorial?
CARAM
EBERLAZARE_I_Intel
Cool! If you have other question, don't hesitate to post a new questions.
