Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1235 Discussions
parity checker with reset
AManj1
my program is:
module detector (s_out, s_in, reset, clk);
  input s_in, reset, clk;
  output s_out;
 reg s_out;
 reg state;
 parameter even=0,odd=1;
 always@(posedge clk or reset)
  begin
   if(reset)
    state<=even;
   else
    case(state)
     0:begin
      state<=s_in?odd:even;
      s_out<=s_in?1:0;
     end
     1:begin
      state<=s_in?even:odd;
      s_out<=s_in?0:1;
     end
     default:state<=even;
    endcase
  end
endmodule
but the program is not working for most test cases...help
KhaiChein_Y_Intel
Could you elaborate in details? Do you mean compilation error? Could you provide the error message?
AManj1
the program question is:
It is required to implement a sequence detector that will accept a serial bit stream “s_in” in synchronism with the positive edge of a clock, and will generate a serial bit stream “s_out” as output. The next bit of “s_out” will be 1, if the number of 1’s in “s_in” seen so far is odd; it will be 0 otherwise. The state transition diagram will consist of two states indicating whether the number of 1’s seen so far is odd or even. A “reset” low signal is used to asynchronously initialize the state to the “even 1’s state”.
my program:
 output s_out;
 reg s_out;
 reg state;
 begin
  if(!reset)
  state<=even;
  else
  case(state)
   0:begin
   s_out<=s_in?1:0;
   end
   1:begin
   s_out<=s_in?0:1;
   end
  endcase
 end
endmodule
result of testcases:
Compilation : Passed
Public Test Cases: 1 / 4
Test Case 1
Pass: (state = x, s_in = 0, reset = 0) => (state = 0, s_out = x, reset = 0)\n
Passed
Test Case 2
Pass: (state = 0, s_in = 1, reset = 1) => (state = 1, s_out = 1, reset = 1)\n
Fail: (state = x, s_in = 1, reset = 1) => (state != 0, s_out != x, reset != 1)\n
Wrong Answer
Test Case 3
Pass: (state = 1, s_in = 1, reset = 1) => (state = 0, s_out = 0, reset = 1)\n
Fail: (state = 0, s_in = 1, reset = 1) => (state != 1, s_out != 1, reset != 1)\n
Wrong Answer
Test Case 4
Pass: (state = 1, s_in = 0, reset = 1) => (state = 1, s_out = 1, reset = 1)\n
Fail: (state = 0, s_in = 0, reset = 1) => (state != 0, s_out != 0, reset != 1)\n
Wrong Answer
KhaiChein_Y_Intel
In an Event Control in the HDL, you specified an Event Control that contains both double-edge events and single-edge events. You cannot include both event types in one Event Control.
I edited the HDL and the simulation result is correct.
KhaiChein_Y_Intel
AManj1
Thank you Sir. I just learned something new.But even after modification,some private test cases are wrong
i will get an exact answer by tomorrow and will update the program here as soon as possible
KhaiChein_Y_Intel
Sure.
AManj1
  output s_out;
  parameter EVEN=1'b0, ODD=1'b1;
  reg s_out, state;
  always @(posedge clk, reset)
    begin
      if (!reset)
    state <= EVEN;
      else begin
        case ({state,s_in})
          2'b00,2'b11: begin
                  s_out <= 1'b0;
                  state <= EVEN;
                 end
          2'b01,2'b10: begin
                  s_out <= 1'b1;
                  state <= ODD;
                 end
        endcase
      end
    end
endmodule
allthough i think its the same program in a different way!!!!!!
AManj1
any idea on how to implement this program?
Write a Verilog module to implement a 32-bit Booth’s multiplier using behavioural style. The module will take two 32-bit multiplier (“mpr”) and multiplicand (“mpd”) as inputs, and produce a 64-bit product (“prod”) as output. An active high input signal “start” is used to start the multiplication, and after completion of the multiplication, a signal “done” will be set to 1.and carry out the tasks at any individual stage including state transition in the failing edge of an input clock “clk”.
The following module template must be used for implementation:
module booth (mpr, mpd, prod, start, done, clk);
  input [31:0] mpr, mpd;
  input start, clk;
  output [63:0] prod;
  output done;
KhaiChein_Y_Intel
May I know the status? Have you resolved the first error with the HDL code I have attached earlier?
For the second question, you may refer to a video published by Intel FPGA: Verilog HDL Basics
https://www.youtube.com/watch?v=PJGvZSlsLKs. The video shows how to implement behavioural statement at 31:02mins.
AManj1
yes the issue was resolved.
Thank you.
AManj1
the program i came up with is:
  input start, clk;
  output [63:0] prod;
  output done;
 integer i;
 reg [31:0] A, Q, M;
reg Q_1;
 reg [5:0] count;
 initial
   begin
A <= 32'b0;
M <= mpd;
Q <= mpr;
Q_1 <= 1'b0;
count <= 6'b100000;
   end
 always@(negedge clk)
  begin
case ({Q[0], Q_1})
 2'b00 : {A, Q, Q_1}=A<<<Q<<<Q_1;
 2'b01 : begin
  A=A+M;
 end
 2'b10 : begin
  A=A-M;
 end
 2'b11:{A, Q, Q_1}=A<<<Q<<<Q_1;
endcase
 count=count-1'b1;
end
assign prod = {A, Q};
 assign done = (count==0);
endmodule
no compilation errors but not working for these test cases:
Test Case 1
0
Pass: (start = 1, mpr = 16, mpd = 10) => (clock cycles = 37, prod = 160, done = 1)\n
Fail: (start = 1, mpr = 16, mpd = 10) => (clock cycles = 37, prod != X, done != 0)\n
Wrong Answer
Test Case 2
1
Pass: (start = 0, mpr = 16, mpd = 10) => (clock cycles = 37, prod = x, done = x)\n
Fail: (start = 0, mpr = 16, mpd = 10) => (clock cycles = 37, prod != X, done != 0)\n
Wrong Answer
Test Case 3
2
Pass: (start = 1, mpr = 75, mpd = 20) => (clock cycles = 41, prod = 1500, done = 1)\n
Fail: (start = 1, mpr = 75, mpd = 20) => (clock cycles = 41, prod != X, done != 0)\n
Wrong Answer
Test Case 4
3
Pass: (start = 1, mpr = 85, mpd = 60) => (clock cycles = 43, prod = 5100, done = 1)\n
Fail: (start = 1, mpr = 85, mpd = 60) => (clock cycles = 43, prod != X, done != 0)\n
Wrong Answer
KhaiChein_Y_Intel
It is glad to hear that the first issue was resolved.
For the second issue, may I request the design file and simulation result?
KhaiChein_Y_Intel
May I know if you have any updates?
