Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1237 Discussions
Reset and tutorial Using the SDRAM on Altera's DE0-Nano Boards
The tutorial Using the SDRAM on Altera's DE0-Nano Boards uses the Clock Signals IP Core to provide a clock to the SDRAM.
But I found that pressing the Key(0) was not resetting.
Indeed, in altera_up_altpll.v the reset is not connected to areset of the altpll instance.
Here is a correction:
altpll PLL_for_DE_Series_Boards ( // Inputs .inclk ({1'b0, refclk}), .areset (reset), // Outputs .clk ({3'b0, outclk2, outclk1, outclk0}), .locked (locked), ); defparam PLL_for_DE_Series_Boards.port_areset = "PORT_USED",
It works fine, but let me know if I overlooked something.
rsoff
hello,
i am trying to work with he same tutorial.
everything works fine except that the key(0) is not resetting.
i tried to use your correction but still with no success.
i noticed that in "nios_system.v" file, the reset defines as "reset_reset" and not as "reset_reset_n" as it should be:
perhapes it might be the problem.
what should i do to change it?
thanks in advance.
