Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1237 Discussions
Terasic RFS module, compilation errors since Quartus version 16.1
luis6
I own the Terasic RFS module (Wifi+BT+sensors).
The software that comes with this module used to compile fine with Quartus 16.1.
The software I refer to is any of the examples using the UART IP (for instance Wifi and BT examples).
With any Quartus version after 16.1 it gives some errors related to "clock no initialized" on the UART IP. I have tried to add a new clock (as suggested on some forums) but it does not help.
Also I have found that Quartus 16.1 UART IP is not the same on later versions.
My question is simple: has anyone been able to compile the Terasic RFS examples with any Quartus version greater than 16.1? Quartus 16.1 is not available for download anymore. The oldest version available for download is 17.0.
In case you are wondering why I have not asked this to Terasic itself is because they forward questions to this forum.
Any help is appreciated.
inaki.
Farabi
This design was built by Terasic. Do you have the link to download? Do you know why Terasic cannot support the design upgrade? They supposed to upgrade their design.
regards,
Farabi
Farabi
I tried to compile the RFS design with Quartus 21.1 lite edition. It can compile successfully.
Have you ever tried to compile the design? attached is the design archive.
Farabi
you just need to upgrade the IP with Quartus.
regards,
Farabi
luis6
Thanks for your help.
I Am using Quartus Lite 21.1.
When I load the project, apparently the UART IP is already upgraded to version 17.1 (from 16.1).
The button "Upgrade" on the IP Upgrade Panel is grayed out, so I cannot see any way to upgrade it further.
Please note that I am compiling the "DE115 Wifi Time RTL".
So far, I am unable to compile the project.
Farabi
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
regards,
Farabi
