Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1238 Discussions
What is the problem of my simulation of "WAVEFORM VECTOR FILE"?
HSlam
After I draw an electronic circuit, I tray to do a simulation with "WAVEFORM VECTOR FILE" but when I execute my simulation I have this erreur : (
Error (199014): Vector source file E:/intelFPGA_lite/18.1/PROJET COS X/Waveform.vwf specified with --testbench_vector_input_file option does not exist
Error: Quartus Prime EDA Netlist Writer was unsuccessful. 1 error, 1 warning
Error: Peak virtual memory: 488 megabytes
Error: Processing ended: Mon Mar 25 15:14:02 2019
Error: Elapsed time: 00:00:00
Error: Total CPU time (on all processors): 00:00:01
Error. )
Can you help me please.
Vicky1
Hi Hammia,
Please follow the below steps,
  1. "Simulation" Menu-> "Simulation Settings"
  2. Perform "Restore Defaults "
  3. Then"Save"
Refer the below screenshot & let me know if this has resolved your issue,
Vikas
HSlam
I follow the bellox steps
3.      Then"Save"
this time the execution has progressed but it displays the following message:
# ** Error: Waveform3.vwf.vht(36): near "0": (vcom-1576) expecting IDENTIFIER.
# ** Error: Waveform3.vwf.vht(72): Integer literal 0 is not of type ieee.std_logic_1164.STD_LOGIC.
# ** Error: Waveform3.vwf.vht(87): VHDL Compiler exiting
# End time: 12:03:30 on Mar 27,2019, Elapsed time: 0:00:00
# Errors: 3, Warnings: 0
# ** Error: e:/intelfpga_lite/18.1/modelsim_ase/win32aloem/vcom failed.
# Executing ONERROR command at macro ./COSX.do line 4
Error.
Look please at the below screenshot : CaptureErreur.JPG
Vicky1
Hi Hammia,
"this time the execution has progressed but it displays the following message"
That`s nice, now error is at line 32 of Waveform3.vwf.vt, open that file & try to debug the issue.
If you provide your project(Project->Archive Project) that will be easier to others to support.
Vikas
