Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1238 Discussions
alt_up_vga_dev* alt_up_vga_open_dev(const char* name);
hello,i am the first time use university program VGA core.
I don't know the function alt_up_vga_dev* alt_up_vga_open_dev(const char* name); how to use and (alt_up_vga_dev *vga) what's this? Please help me!My Board is DE2.:) thanks!
the function define in ALTERA_UP_AVALON_VGA_H.
I guess everything is well explained in 'VGA core for Altera DE1/DE2 boards' document available at ftp://ftp.altera.com/up/pub/university_program_ip_cores/vga.pdf.
Thanks! i had readed VGA.pdf,but it wouldn't run on DE2 board.i build NIOSii+SDRAM+VGA Core(no buffer)+Development Board External Interface(VGA clk+SDRAM clk). i want to ask a question about VGA Core CLK.IN VGA pdf,the VGA Core need 25Mhz.avalon_pixel_slavePort need 50Mhz.
https://www.alteraforum.com/forum/attachment.php?attachmentid=547
SO i need to change the red circel to 25mhz?
please every one tall me how could i do?
the monitor has signal without ANSI C and Function?(Just download .sof)
please help me !Thanks!
I don't know the function int alt_up_vga_draw_pixel(alt_up_vga_dev *vga, alt_u32
pixel, alt_u32 x, alt_u32 y); how to use and (alt_up_vga_dev *vga) what's this? My Board is DE2. I can't set pixel on monitor . I want to set pixels on monitor. I write source C to set pixels. I don't know to use int alt_up_vga_draw_pixel(alt_up_vga_dev *vga, alt_u32 pixel, alt_u32 x, alt_u32 y); Please help me!.Thank.
Hi, i the first time use university program VGA core.
pixel, alt_u32 x, alt_u32 y); how to use and (alt_up_vga_dev *vga) what's this? Please help me!My Board is DE2. I can't set pixel on monitor. What is pointer VGA?What is the pointer to the VGA structure pixel? Help me .Thank.
Hi you,
you can divide clock 50Mhz by using file PLL to have clock 25Mhz. I have project use VGA core. My project is output signals, i use clock 25Mhz (ok).I'm using ANSI C and Function. But i don't the function int alt_up_vga_draw_pixel(alt_up_vga_dev *vga, alt_u32
pixel, alt_u32 x, alt_u32 y);I want to use it. we can discuss together.OK
hi where are you from?
i was sucessfull for this ip
:confused: v03820 can you post how you got it working.
:( All I get is a screen full of colored dots and no ability to plot points.
:D I'm using a DE1 board.
Enya.
