Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
helpless
mark_lee
I  use the IP "intel_generic_serial_flash_interface" in my project , when i run the project , i get an error about this :
Error(12790): Can't use active serial memory interface block -- configuration scheme is not Active Serial
Error(16297): An error has occurred while trying to initialize the plan stage.
Error: Quartus Prime Fitter was unsuccessful. 2 errors, 1 warning
Error: Peak virtual memory: 7414 megabytes
Error: Processing ended: Tue Nov 17 18:56:13 2020
Error: Elapsed time: 00:00:52
Error(293001): Quartus Prime Full Compilation was unsuccessful. 3 errors, 53 warnings
YuanLi_S_Intel
Hi Mark,
From the error message, seems like the configuration scheme you selected is not Active Serial. Also, can you please check if you are programming with JIC bitstream?
Thank You
