Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1238 Discussions
how to use getch in niosII
hi i want to ask what is the header file to add for using getch in niosII. I had try to add conio.h but it say that No such file or directory.
thx for helping:)
getch() and <conio.h> aren't standard C. You can use getchar() (http://sourceware.org/newlib/libc.html#getchar) instead (that you'll find in <stdio.h>)
but getchar is different function with getch o
What you want to achieve with this getch()?
How does the getchar() gon't suite your need?
May be you can post your code here?
Yes, now i trying to use getchar() but there still some problem with it because i using "string" to do it but when i change to "int" or "char" it can be done. The problem is when i using string the password that i type out is correct (i already prove by typing: printf (%s, &password) ) but it still cant be match with the password that i had set. I making a program that need to type password to log in, when typing password those character will become ***, by the way i still dun know the programming change to *** is correct or not. Thx for helping
my coding show as below:# include <stdio.h># include <stdlib.h># include <unistd.h># include <string.h>
void one();
void two();
int login ;
int user ;
char password[10];
int i = 0;
char c;
int main ()
while(1){
printf ("---------------------------\n");
printf (" Main Menu\n");
printf ("----------------------------\n");
printf (" 1.Admin login\n 2.User login\n");
scanf("%i", &login);
if (login == 1)
two();
if (login == 2)
printf ("Display\n");
return(0);
void one()
menu:
printf (" User Menu\n");
printf (" 1.Check User\n 2.Delete User\n 0.Main Menu\n");
scanf("%i", &user);
if (user == 1)
printf ("CHECK\n");
else if (user == 2)
printf ("DELETE\n");
else if (user == 0)
main ();
else if (user != 1,2,0)
printf ("Wrong key please retry\n");
goto menu;
else
NULL;
void two()
printf ("Please enter password: ");
enter:
scanf("%s", &password);
while(i<5){
c = getchar();
password = c;
printf("*");
i++;
getchar();
i=0;
while (i<5)
printf("%c",pass);
i++;
getchar();
if (password == 'obc')
one();
else if (password != 'obc')
printf ("Wrong password, please retype ");
goto enter;
else
NULL;
ps: previously those getchar i use getch for it
