Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1237 Discussions
vhdl stopwatch with LPM RAM
I am doing a lab assignment about a VHDL stopwatch.
this watch can store 16 32-bits timestamp in the memory.
and when readmode = '1', the stopwatch will show the timestamps.
below is my code.(the other modules are working fine, only this one doesn't work yet.) could anybody tell me what is wrong with it?
I really appreciate it.
--- Quote Start ---
LIBRARY ieee;
USE ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.numeric_std.all;
entity stopwatch is
port
clk : in std_logic;
readmode : in std_logic;
reset : in std_logic;
store : in std_logic;
data_ram : in std_logic_vector(31 downto 0);
data_clock : in std_logic_vector(31 downto 0);
addr_user : in std_logic_vector(3 downto 0);
ram_write_en: out std_logic;
addr : out std_logic_vector(3 downto 0);
data : out std_logic_vector(31 downto 0)
end stopwatch;
ARCHITECTURE arch_stopwatch of stopwatch is
TYPE state_type IS (s0,s1,s2,s3,s4,s5,s6,s7,s8,s9,s10,s11,s12,s13,s14,s15,s16);
signal state : state_type := s0;
signal stage : std_logic_vector(3 downto 0);
signal flag : std_logic_vector(1 downto 0);
signal c_store, n_store : std_logic;
signal fall_edge : std_logic;
begin
flag <= reset & readmode;
n_store <= store;
fall_edge <= c_store and ( not n_store );
process(clk, reset)
begin
if( reset = '1' ) then
c_store <= '1';
elsif( rising_edge(clk) ) then
c_store <= n_store;
end if;
end process;
process
variable r_counter : std_logic_vector(3 downto 0);
begin
WAIT UNTIL (clk'event and clk = '1');
if( flag = "10" or flag = "11" ) then
stage <= "0000";
state <= s0;
ram_write_en <= '1';
--addr <= (others => '0');
data <= (others => '0');
------------------------reset Memory------------------------
for i in 0 to 15 loop
addr <= r_counter;
r_counter := r_counter + 1;
end loop;
elsif( flag = "00" ) then
data <= data_clock;
-------------store time---------
CASE state IS
WHEN s0 =>
ram_write_en <= '0';
stage <= "0000";
state <= s1;
when s1 =>
if(fall_edge = '1') then
addr <= stage;
stage <= stage + 1;
else
end if;
if( stage = "1111" ) then
state <= s2;
else
state <= s1;
end if;
when s2 =>
when others =>
state <= s0;
END CASE;
elsif( flag = "01" ) then
addr <= addr_user;
data <= data_ram;
end if;
end process;
end arch_stopwatch;
--- Quote End ---
First problem I see:
------------------------reset Memory------------------------ for i in 0 to 15 loop addr <= r_counter; r_counter := r_counter + 1; end loop;
Your address actually increments by 16 on each clock, so the addresses in between are not written to.
Also, you have included std_logic_unsigned and numeric_std. You should only use one or the other - (numeric_std is a standard package, std_logic_unsigned is not an IEEE standard).
Did you have any problems other than these?
