0xC0000005 Access Violation Writing Location Error
emreka82
Principiante
28.027 Vistas
I am writing a code with large arrays. The code works fine for small matrices but when I go beyond a certain level, the following error pops out:
Unhandled exception at 0x77913560 in 3d.exe: 0xC0000005: Access violation writing location 0x0000000000050e14.
I am dynamically allocating memory with variables, then deallocating them. The code is very long, longer than 20,000 lines. I want to trace the problem. Before deciding to start this topic, I search the forum and other sources. The "Stack Size" problem has seemed reasonable. I changed reserve size to 200,000,000 and commit size 20,000,000. The problem stayed the same with small differences:
Unhandled exception at 0x77913560 in 3d.exe: 0xC0000005: Access violation writing location 0x00000000001e0e84.
As you can see the code given at the end of the error line is different, I want to know and trace the error. Any kind of help will be appreciated. Thanks !
Emre
0 kudos
93 Respuestas
TimP
Colaborador Distinguido III
3.609 Vistas
If you have VS2008 or earlier, you must specifically add the X64 components in the installation menu under C++, then apply service packs and re-install Intel64 compilers.
Bernard
Colaborador Valioso I
3.609 Vistas
emreka82 wrote:
Quote:
iliyapolakwrote:
@emreka82
Why do not you try to use windbg and application verifier in order to automate the error finding task.
I will give a try, it is on my list. Before installing these kind of  programs, I applied the effects of change in Visual Studio, Virtual Memory etc. Once I am done with these changes, I will install both windbg and application verifier. Thanks iliya.
Good decision.
emreka82
Principiante
3.609 Vistas
Sergey Kostrov wrote:
>>...I cannot change the target machine. It has "MachineX86 (/MACHINE:IX86)" or "not Set" selections. I have 64bit Windows operating
>>system...
It looks like a Root Cause of your problems because MachineX86 (/MACHINE:IX86) is a setting for 32-bit platforms and 32-bit applications can not allocate more then 2GB of memory.
>>...Why can't it change?..
Please ptovide exact details for a Visual Studio you use.
I use VS 2010 version 10.0.40219.1 SP1Rel
SergeyKostrov
Colaborador Valioso II
3.609 Vistas
Emreka82, Could you create and attach a simple Fortran project for a review? It is really Not clear why you could not change the Target Machine. Thanks in advance. Please take into account that with a 64-bit application maximum amount of memory a 64-bit application can allocate is more than 1TB ( of course a system must have it installed ). So, there should not be any limitations for Stack/Heap Commit and Stack/Heap Reserved values if the Target Platform is 64-bit.
emreka82
Principiante
3.609 Vistas
Emreka82,
Yes, I open a simple Fahr_to-Celc project implied from Fortran90 textbook and under linker advanced options multiple machine types (MachineX64, SH4, X86 etc)
SergeyKostrov
3.609 Vistas
>>Yes, I open a simple Fahr_to-Celc project implied from Fortran90 textbook and under linker advanced options >>multiple machine types (MachineX64, SH4, X86 etc) Did you remove Read Only attribute for project files after you've copied the project to a hard drive?
emreka82
Principiante
3.609 Vistas
I don't remove but all of the f90 files and other project files are NOT read only as default. By the way, all the files and the program are in D harddisk part not in C harddisk part. Does it make a difference ?
emreka82
Principiante
3.609 Vistas
I think I found the problem, If you agree then I should reinstall the program. The program that I use is x86. The destination to VS developer is "C:\Program Files (x86)\Microsoft Visual Studio 10.0\Common7\IDE\devenv.exe"
Under x64 part of my program files ("C:\Program Files\Microsoft Visual Studio 10.0\Common7\IDE\") destination there are only vsdiag_regwcf.exe file with PrivateAssemblies and Xml folders...
SergeyKostrov
3.609 Vistas
>>...all the files and the program are in D harddisk part not in C harddisk part. Does it make a difference? No, it should not. Please verify how much free space you have on the drive D. >>...I think I found the problem, If you agree then I should reinstall the program. The program that I use is x86... In that case Visual Studio installer ( for example Repair option ) should tell you exactly if 64-bit builts are supported in your current (!) environment. Also, try to use MS Depends utility ( it is very simple ) to verify that your current executables are 32-bit. After 64-bit support in Visual Studio is installed Re-Build the sources and check the executable with MS Depends again and it should show small 64 numbers if the module is for a 64-bit platform.
emreka82
Principiante
3.609 Vistas
>>....Also, try to use MS Depends utility ( it is very simple ) to verify that your current executables are 32-bit. After 64-bit support in Visual Studio is installed Re-Build the sources and check the executable with MS Depends again and it should show small 64 numbers if the module is for a 64-bit platform.
I use dependency walker. I open "....3d\x64\Debug\3d\3d.exe file.  It gives only "Could not find the section that own the Import directory" warning.
SergeyKostrov
3.609 Vistas
>>...I use dependency walker. I open "....3d\x64\Debug\3d\3d.exe file. It gives only "Could not find the section that own the Import >>directory" warning... Could you post a screenshot? Unfortunately, I don't have a Crystal Ball and I can not see what is going on with MS Depends or your computer. Here are a couple of notes: - For a 64-bit Fortran application a linker option Target Machine has to be set as Not Set - Attached is a test project ( a simple matrix multiplication ) and please take a look Note: I use the test project to test my system and more than 128GB of memory successfully allocated when two 64Kx64K matricies multiplied
Bernard
3.609 Vistas
emreka82 wrote:
Can you run dumpbin or LordPE. on the 3d.exe  IAT table?It seems that dependency walker has a problem with finding imports section or it could be also packed executable.
emreka82
Principiante
3.609 Vistas
The screenshot is attached.
I use it with a 48 GB virtual memory, two 16Kx16K matrices are multiplied successfully.
emreka82
Principiante
3.609 Vistas
I use dumpbin. The output is as follows:
C:\Program Files\Microsoft Visual Studio\VC98\BIN>dumpbin/out:E:\3d\3d\3d\x64\Debug/3d.exe
Microsoft (R) COFF Binary File Dumper Version 6.00.8447
Copyright (C) Microsoft Corp 1992-1998. All rights reserved.
After that, the dependency walker gives error again. The screenshot is attached.
SergeyKostrov
3.609 Vistas
>>...I use it with a 48 GB virtual memory, two 16Kx16K matrices are multiplied successfully. It is a good news. Now, please take a look at another useful option of the Intel Visual Fortran compiler ( in a Visual Studio ): Configuration Properties -> Fortran -> Code Generation -> Enable Recursive Routines = Yes Regarding a problem with MS Depends: - If you're using a computer with Windows 7 operating system open the Windows Task Manager and take a look at a list of programs and all 32-bit programs will have suffix *32. For example: - If you see 3D.exe *32 - this is the 32-bit program - If you see 3D.exe - this is the 64-bit program Could you attach 3D.exe ( Release configuration(s) in a ZIP file! ) for my review with MS Depends?
Bernard
3.609 Vistas
>>>After that, the dependency walker gives error again. The screenshot is attached>>>
Could that be a parsing error?.What is the output produced by dumpbin?Can you download a free IDA PRO version and parse 3d.exe PE file?
While working with IDA you need to look for "MZ" ASCII identifier (0x5A4D in hex).
Bernard
3.609 Vistas
>>>C:\Program Files\Microsoft Visual Studio\VC98\BIN>dumpbin/out:E:\3d\3d\3d\x64\Debug/3d.exe Microsoft (R) COFF Binary File Dumper Version 6.00.8447 Copyright (C) Microsoft Corp 1992-1998. All rights reserved.>>>
Is the output above the only output produced by dumpbin?
emreka82
Principiante
3.609 Vistas
iliyapolak wrote:
@emreka82
Hi iliya,
I tried all the suggestions and cannot progress. So, I will try the Windows SDK installation as you suggested. Can you help me with the procedure to follow while searching for the problem ? Thanks.
Emre
Bernard
3.549 Vistas
Yes I will help you.
What have you already done can you describe me?
emreka82
Principiante
3.549 Vistas
I open Windbg(x64) now, and open executable file (3d) (...File....Open Executable). The output is:
Microsoft (R) Windows Debugger Version 6.2.9200.20512 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
CommandLine: E:\3d\3d\3d\x64\Debug\3d.exe
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
ModLoad: 00000001`3fec0000 00000001`40672000 3d.exe
ModLoad: 00000000`778f0000 00000000`77a99000 ntdll.dll
ModLoad: 00000000`77420000 00000000`7753f000 C:\Windows\system32\kernel32.dll
ModLoad: 000007fe`fe070000 000007fe`fe0db000 C:\Windows\system32\KERNELBASE.dll
ModLoad: 000007fe`fea80000 000007fe`fea99000 C:\Windows\system32\imagehlp.dll
ModLoad: 000007fe`fe120000 000007fe`fe1bf000 C:\Windows\system32\msvcrt.dll
ModLoad: 000007fe`fed80000 000007fe`fee5b000 C:\Windows\system32\ADVAPI32.dll
ModLoad: 000007fe`fea60000 000007fe`fea7f000 C:\Windows\SYSTEM32\sechost.dll
ModLoad: 000007fe`fe2f0000 000007fe`fe41d000 C:\Windows\system32\RPCRT4.dll
(1764.16c0): Break instruction exception - code 80000003 (first chance)
*** ERROR: Symbol file could not be found. Defaulted to export symbols for ntdll.dll -
ntdll!CsrSetPriorityClass+0x40:
00000000`7799cb60 cc int 3
Bernard
3.549 Vistas
>>>CommandLine: E:\3d\3d\3d\x64\Debug\3d.exe Symbol search path is: *** Invalid ***>>>
You need to set valid symbol path.For casual debugging the best option is to use microsoft debug symbol server.Please at debug console enter this command: .sympath SRV*c:\symbols folder name*http://msdl.microsoft.com/download/symbols  , next execute .reload command.
Responder
