2015 Initial Release vs 2013 SP1 Update 4 Build Dates
chauvjo
Why is the build date for Fortran 2013 SP1 Update 4 (August 5)  more recent than 2015 Initial Release (July 23)?  I would assume that the 2015 release would be the most current  (see attached PDF)
Steven_L_Intel1
Different code bases. We did the build for 2013 SP1 Update 4 later (there is typically a 6 week gap between the build of a major release and its availability. The 2015 code base has more in it - 2013 SP1 Update 4 has just a few targeted bug fixes for customers who don't yet want to change versions.
chauvjo
OK...So which version has the latest Fortran compiler?  I noticed that Intel Software Manager does not show 2015 Initial Release as available to install. Sorry about the confusion...
Steven_L_Intel1
The 2015 release is the one you want if you want new stuff.
You are correct that Intel Software Manager doesn't tell you about new releases.
