2018 unformatted read grabbing multiple records
Robert_M_1
We have some code that attempts to determine how many entries are in a record by attempting to read the record and looking at the IOSTAT value to determine if we have read too many values.  This code behaves differently with ifort 18, apparently reading multiple records to try and fill the provided array and not giving any indication of an error.  The code below is a simple test case:
program iotest
    implicit none
    integer :: iErr, tmpData(10)
    tmpData = [1,2,3,4,5,6,7,8,9,10]
    open(unit=1, file='testfile.tmp', status='NEW', form='UNFORMATTED')
    write(1) tmpData(1:5) ! Record 1 has 5 values
    write(1) tmpData(3:10) ! Record 2 has 8 values
    close(1)
    tmpData = -1
    open(unit=2, file='testfile.tmp', status='OLD', form='UNFORMATTED')
    read(2, IOSTAT=iErr) tmpData(1:10) ! Try to read 10 values from record 1
    close(2)
    print *, iErr, tmpData
end program
When run with previous versions of ifort, iErr will contain a value of 67 and tmpData will only have its first 5 entries overwritten.  With ifort 18, iErr is 0 and all 10 values of tmpData are populated, pulling the last 5 values from the second record:
Compiler is ifort (IFORT) 15.0.7 20160518
Copyright (C) 1985-2016 Intel Corporation.  All rights reserved.
Compile flags are '-O0'
          67           1           2           3           4           5
          -1          -1          -1          -1          -1
Compiler is ifort (IFORT) 16.0.4 20160811
          67           1           2           3           4           5
          -1          -1          -1          -1          -1
Compiler is ifort (IFORT) 17.0.3 20170404
Copyright (C) 1985-2017 Intel Corporation.  All rights reserved.
          67           1           2           3           4           5
          -1          -1          -1          -1          -1
Compiler is ifort (IFORT) 18.0.1 20171018
           0           1           2           3           4           5
           3           4           5           6           7
I'm not sure if this is a bug or I'm just misunderstanding something (I rarely use Fortran) so any insight would be appreciated.
Steve_Lionel
Your understanding is correct - the 18.0 behavior is not. Please report this at the Intel Online Service Center.
Robert_M_1
Thanks for the quick response.  I have reported it as requested (I think ... those forms don't seem well suited to technical bug reports).
