29279 Discussions
2021 ifort installation for abaqus 2020 fea tool to run subroutines
kumaranup
Hi all I am facing issue in running my abaqus fea subroutines with my fortran ifx version(2025.0.4 20241205) compiler so I need an older version specificaly 2021 version to fix this issue.
Can anyone tell me how to resolve this.
Anup kumar pandey
JohnNichols
Valued Contributor III
Read the notes posted at the top of the forum.
kumaranup
Could you please elaborate in a simplified way.. Thanks!!
kumaranup
May be this can help.!
JohnNichols
When you logon onto this forum there is a list of pinned notes.  One of these notes says read me before you post.
Clearly you did not as one of these posts tells one how to logon onto abaqus
The reason these notes are there is because many people ask this question and we are a FORTRAN forum not an abaqus forum.
If you are using abaqus you should be able to solve small batch file problems to get a program running by reading the notes and the manual.
When I use abaqus I read the manual.
Good luck,
kumaranup
Ohkk thanks for the help
