64bit Fortran Compiler Aborted
kevin2
Sorry, I find it very difficult to find the right place to submit things in the Intel Forum, but I have some F90 code which compiles using the 32bit Intel compiler but causes a fatal internal compiler error (C00000005) when using the 64bit compiler. I have tried locating the error, but it is obviously in the post processing stage. Where do I submit this error and send the code for examination? Thanks. (Also can't work out how NOT to withhold my name - Sorry - K Bradly)
andrew_4619
The name withheld is because your screen name cannot be your login ID or email. I recall it is takes a pity of searching in your user profile to find the name to change which I think is by clicking something that is not at first obvious....
"internal compiler error" is always a bug so file a ticket at the service centre (see the sticky topic at the top of this forum).
kevin2
Sorry I cannot see where to submit a ticket for a bug
mecej4
You can file a report at https://supporttickets.intel.com/servicecenter?lang=en-US, if you have a support account. The FAQ regarding such matters is at https://software.intel.com/en-us/faq/priority-support .
