- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Here is another ICE from ifort 19.0.0
File library.F90:
Module Section_Class implicit none Type :: InputSection_Type contains procedure :: Exists End Type Interface Module Subroutine ReadSections( Sections ) type(InputSection_Type) ,intent(in) :: Sections End Subroutine Module Function Exists(This) result(Res) class(InputSection_Type) ,intent(in) :: This logical :: Res End Function End Interface End Module SubModule(Section_Class) InputSection_SubClass implicit none contains Module Procedure ReadSections End Procedure Module Procedure Exists End Procedure End SubModule Module Input_Class implicit none Type :: Input_Type End Type End Module Module Library use Section_Class ,only: ReadSections use Input_Class ,only: Input_Type implicit none private public :: ReadSections public :: Input_Type End Module
File example.F90
Module MyModule ! use Library ,only: Input_Type ! Workaround implicit none Interface Module Subroutine Proc( Input ) use Library ,only: Input_Type ! Bug class(Input_Type) ,intent(in) :: Input End Subroutine End Interface End Module SubModule(MyModule) MySubModule implicit none contains Module Procedure Proc End Procedure End SubModule
and the script to compile:
#! /bin/bash Compile() { ifort -v ifort -c library.F90 ifort -c example.F90 rm -f *.o *.mod *.smod } source /opt/intel/compilers_and_libraries_2018.0.128/linux/bin/compilervars.sh intel64 Compile source /opt/intel/compilers_and_libraries_2019.0.117/linux/bin/compilervars.sh intel64 Compile
When running the script, I get the following error:
./build.sh ifort version 18.0.0 ifort version 19.0.0.117 /tmp/ifortwDW6H6.i90: catastrophic error: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error. compilation aborted for example.F90 (code 1)
링크가 복사됨
1 응답
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
A request support (03651378) has been issued on the Online Service Center for this ICE.
