29418 Discussions
Incorrect (or strange) reporting of array shape checking option when pointer lbound remapping is used.
artu72
In the release 2019 of Intel Fortran compiler there is now the new option of array shape checking, as reported here:
https://software.intel.com/en-us/articles/array-shape-check-new-in-intel-fortran-compiler-190
Now, in the following code
program intele33
implicit none
integer, dimension(8,2), target :: i
integer, dimension(:), pointer :: j
j(1:) => i(:,2)
end program
while running I obtain the following warning (compiled with check all option):
forrtl: warning (406): fort: (33): Shape mismatch: The extent of dimension 1 of array J is 0 and the corresponding extent of array I is 8
but the resulting code is however perfectly working. gfortran does not issue this warning.
If I remove the lbound remapping
j => i(:,2)
there is no warning/error.
This is strange, since in both cases the pointer i has lower bound 1.
Juergen_R_R
Valued Contributor II
I do not get any warning with the 19.0 release version neither for -check shape nor with -check all.
artu72
I removed this post since I ahve updated the first post and topic with a more precise description of the issue.
artu72
I have updated the issue description, please read it. Thank you.
Juergen_R_R
Ok, I overlooked that it is a runtime error message. This indeed looks like a compiler bug to me.
