- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
LoadLibraryA("MSVCR80.DLL") called from "LIBMMD.DLL" at address 0x00CB7A8E.
Loaded "MSVCR80.DLL" at address 0x074D0000. Successfully hooked module.
DllMain(0x074D0000, DLL_PROCESS_ATTACH, 0x00000000) in "MSVCR80.DLL" called.
GetProcAddress(0x7C800000 [KERNEL32.DLL], "IsProcessorFeaturePresent") called from "MSVCR80.DLL" at address 0x074EA9AE and returned 0x7C80AE3A.
GetProcAddress(0x77C10000 [MSVCRT.DLL], "_set_error_mode") called from "MSVCR80.DLL" at address 0x074D4447 and returned 0x77C35348.
GetProcAddress(0x77C10000 [MSVCRT.DLL], "?set_terminate@@YAP6AXXZP6AXXZ@Z") called from "MSVCR80.DLL" at address 0x074D4463 and returned 0x77C22567.
GetProcAddress(0x77C10000 [MSVCRT.DLL], "_get_terminate") called from "MSVCR80.DLL" at address 0x074D447F and returned NULL. Error: The specified procedure could not be found (127).
GetProcAddress(0x7C800000 [KERNEL32.DLL], "FindActCtxSectionStringW") called from "MSVCR80.DLL" at address 0x074D1DBE and returned 0x7C82FD68.
LoadLibraryA("USER32.DLL") called from "MSVCR80.DLL" at address 0x074D96ED.
LoadLibraryA("USER32.DLL") returned 0x7E410000.
GetProcAddress(0x7E410000 [USER32.DLL], "MessageBoxA") called from "MSVCR80.DLL" at address 0x074D9705 and returned 0x7E45058A.
GetProcAddress(0x7E410000 [USER32.DLL], "GetActiveWindow") called from "MSVCR80.DLL" at address 0x074D9722 and returned 0x7E41D658.
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Given that even two DLLs with the same name but different internal version numbers can cause no trouble, it is almost a given that linking against incompatible import libraries will cause trouble.
Each issue of the Intel compiler, along with the MS prerequisites, which may be included with the compiler distribution itself, provides a complete set of libraries to link against. If one's build process circumvents the use of these libraries and uses others, problems are to be expected.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
If this was a general problem in LIBMMD I would expect to have seen this error many times before. Can you give more detail as to how your application is structured and exactly when you see this error R6034?
Intel Fortran 9.0 does not support VS2008.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I will ask the library developers about how (or if) LIBMMD finds the MSVC library, but if it does this it is not dependent on Windows version.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I can find no evidence that 11.0 looks for MSVCR100.DLL. Why do you think it does?
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
How are you determining this "DLL search list"?
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
If you can reproduce an error using 11.1, let us know.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
1) Cana conclusion be made thatthe right libmmd.dll should be
Fortran9.0 - should not has a reference to MSVCR80.dll
Fortran11.0 - should not has a reference to MSVCR100.dll
2) Can an accurate answer be got from LIBMMD developers?
We have distributed a number of our tools to our customers using Fortran 9.0 and Fortran 11.0 and were reported from our customers about such errors, till now we have no solutions for them yet.
We really need your help to get solutions to our customers.
Do we need to file formal bugs through some other formal channels,instead of just the forum here?
Thank you very much for your cooperation
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Steve is on vacation, so let me respond.
You can report issues to the forum (and even upload test cases) or you can file an issue at premier.intel.com.
Looking back through the thread it looks like at this point we need a test case with 11.1 (9.0 and 11.0 are no longer supported) to proceed. It sounds like Steve had checked with the developers and the referencing of libmmd.dll had changed since 9.0 so they could not comment on your question of referencing.
Wendy
