Good day,
I have coded a test
[fortran]PROGRAM main
IMPLICIT NONE
integer, pointer, dimension(:) :: this_ptr
integer :: i
call allocateIt( this_ptr, 1, 5 )
this_ptr = (/ (i,i=1,5) /)
write( *, * ) this_ptr
CONTAINS
subroutine allocateIt(this, from, to)
implicit none
integer, intent(IN) :: from, to
integer, pointer, dimension(:), intent(INOUT) :: this
allocate( this(from:to) )
return
end subroutine allocateIt
END PROGRAM main[/fortran] I have information that pointer and intent can not bespecified to one variable (see an attachment).
The output is
ifort -g -traceback -check all -openmp allocate.f90 -o xmain
./xmain
1 2 3 4 5
Oleg.
Yes, POINTER and INTENT can be specified as of Fortran 2003. Note that in this case the INTENT applies to the pointer itself, not the data it points to.
