Hi:
I have two compiled libraries. Library A carries a function called 'geterror', and Library B happens to carry a different function of the same name.
I only need one 'geterror', how do I instruct the Fortran compiler to ignore the other 'geterror' when linking object codes?
Steven
This is a function of the linker (ld) and not the compiler and you can pass the necessary linker option via the compiler using the compiler option: -Wl,-zmuldefs
The first instance seen of the duplicate named symbol will be used during the link.
The example below links using object files and static archives that contain a duplicate symbol "sub". In the example below, case 1 shows the error you might be hitting; case 2 executes the "subA" instance since subA.o appears ahead of subB.o; case 3 executes the "subB" instance since the static archive libsubB.a appears before libsubA.a.
[bash]subA.f90 ======= subroutine sub print *,"SubA" end sub.f90 subroutine sub print *,"SubB" end test.f90 ====== program test call sub end $ ifort -c subA.f90 $ ifort -c subB.f90 $ ifort -c test.f90 $ ar crv libsubA.a subA.o r - subA.o $ ar crv libsubB.a subB.o r - subB.o $ ifort test.o subA.o subB.o subB.o: In function `sub_': subB.f90:(.text+0x0): multiple definition of `sub_' subA.o:subA.f90:(.text+0x0): first defined here $ ifort -Wl,-zmuldefs test.o subA.o subB.o $ ./a.out SubA $ ifort -Wl,-zmuldefs test.o -L. -lsubB -lsubA $ ./a.out SubB [/bash]
Kevin:
Thank you very much for taking time to help me.
Here's another more tricky situation -- instead of ignoring the other 'geterror', I want to use it later in the same program. Using your example, it is like:
- test.f90
- programtest
- callsub ! Invoke 'sub' in SubA.f90
- call sub ! Invoke 'sub' in SubB.f90
- end
Steven
I'm not aware of a way to accomplish that. If each geterror could have a unique name and the arguments to each differed, then you could define a generic interface for these two and call them using the same name, geterror. The interface determines which actual one is called based on matching the argument types. I'm not sure if that meets with your needs/interests.
In the earlier example, give each subroutine a unique name, subA and subB, with a unique argument. Create a generic interface for the name "sub" and then call subA and subBusing the name "sub". This case no longer requires the linker option because the subroutines have unique names.
[bash]subA.f90 ======= subroutine subA(A) integer, intent(in) :: A write(*,*)"SubA, A=",A end subB.f90 ======= subroutine subB(B) real, intent(in) :: B write(*,*)"SubB, B=",B end test.f90 ======= program test interface sub subroutine subA(A) integer,intent(in) :: A end subroutine subA subroutine subB(B) real,intent(in) :: B end subroutine subB end interface integer :: tA real :: tB tA=1 tB=2.0 call sub(tA) call sub(tB) end $ ifort -c subA.f90 $ ifort -c subB.f90 $ ifort -c test.f90 $ ar crv libsubA.a subA.o a - subA.o $ ar crv libsubB.a subB.o a - subB.o $ ifort test.o -L. -lsubB -lsubA $ ./a.out SubA, A= 1 SubB, B= 2.000000 [/bash]
program test
use libA, subA => sub
use libB, subB => sub
call subA! Invoke 'sub' in SubA.f90
call subB ! Invoke 'sub' in SubB.f90
call foo
call fooBar
end
subroutine foo
use libA
call sub ! Invoke 'sub' in SubA.f90
end subroutine foo
subroutine fooBar
use libB
end subroutine fooBar
Jim Dempsey
Jim:
This is a great workaround. Thank you very much!
Steven
