ASSOCIATE statement
John4
Valued Contributor I
I'm trying to learn to use the ASSOCIATE statement (i.e., trying to see if I understood correctly what such statement intends to do). I have the following test:
program test
implicit none
type tabletype
integer :: p, q
end type
type globaltype
type(tabletype), allocatable :: table(:,:)
end type
integer :: i
type(globaltype), target :: global
integer, pointer :: p2q(:,:)
continue
allocate (global%table(10,10))
ASSOCIATE (p => global%table%p)
p = RESHAPE([(i, i = 1, 100)], [10,10])
write (*,'(10(10I5/))') p
END ASSOCIATE
p2q => global%table%q
p2q = RESHAPE([(i, i = 1, 100)], [10,10])
write (*,'(10(10I5/))') p2q
nullify(p2q)
end program test
When I try to compile this source code, I get:
internal error: Please visit 'http://www.intel.com/software/products/support' for assistance.
[ Aborting due to internal error. ]
compilation aborted for test.f90 (code 1)
So my question is, am I using the ASSOCIATE statement right (i.e., as a replacement for pointers like p2q) or not?
John.
This error has been corrected for a future release.
TimP
I guess this violates the rule against using ASSOCIATE to redefine a name. The compiler ought to say what is wrong, rather than throw an internal error.
John4
Quoting - tim18
Yes, it was my fault for not writing a test case that represents exactly the code I have (i.e., in my code, the target values are never modified when accessed through the pointer). Anyway, the following code stills throws the same internal error:
program test
implicit none
type tabletype
integer :: p, q
end type
type globaltype
end type
integer :: i
continue
global%table%p = RESHAPE([(i, i = 1, 100)], [10,10])
END ASSOCIATE
nullify(p2q)
end program test
Thanks - I can reproduce this and have passed it on to development. Our issue ID is DPD200110830. I will let you know of any progress.
