Fortran calling C library
emmavartdal
I'm having some problems making a Fortran application link with my C libraries. I've had plenty of luck doing it with the gcc C and Fortran compiler, but Intel Fortran(our preferred Fortran compiler) is being a bit difficult.
I'm developing my C library with VS2008, and using Intel Fortan 10 on VS 2005. My C files look like this:
== AC_LIB_STATIC.H ==
#ifndef _AC_LIB_STATIC_H_
#define _AC_LIB_STATIC_H_
extern "C" int ADD(int*, int*, int*);
#endif // _AC_LIB_STATIC_H_
== AC_LIB_STATIC.C ==
int ADD(int* a, int* b, int* answer) {
    int ans;
    ans = (*a+*b);
    *answer = ans;
    *answer = (*a+*b);
    return(1);
The ADD function gets declared as "int __stdcall ADD(int*, int*, int*) " and decorated as "?ADD@@YGHPAH00@Z"
== TEST.F90 ==
    program Console1
    implicit none
    ! Variables
    INTEGER :: A = 1
    INTEGER :: B = 3
    INTEGER :: AN = 0
    ! Body of Console1
    print *, 'Hello World'
    CALL ADD(A, B, AN)
    PRINT *, AN
    end program Console1
And when running this I end up with(After placing ac_lib_static.lib in the library path):
Error  1   error LNK2019: unresolved external symbol _ADD referenced in function _MAIN__  Console1.obj
So, what am I doing wrong here?
Jugoslav_Dujic
Valued Contributor II
Quoting - emmavartdal
int ans;
ans = (*a+*b);
*answer = ans;
*answer = (*a+*b);
return(1);
== TEST.F90 ==
    program Console1
implicit none
! Variables
INTEGER :: A = 1
INTEGER :: B = 3
INTEGER :: AN = 0
! Body of Console1
CALL ADD(A, B, AN)
PRINT *, AN
1) Intel Fortran does not use __stdcall anymore (as CVF did), but __cdecl
2) You must #include "ac_lib_static.h" within ac_lib_static.c, so that the compiler sees that extern "C" (as a rule of thumb, every Foobar.c file should #include its own Foobar.h)
