29235 Discussions
Abaqus 2024 not detecting Intel Fortran compiler (oneAPI + VS 2022)
Aayush_IITR
Hello Intel Community,
Abaqus 2024
Visual studio 2022
Intel base toolkit  & HPC toolkit 2025
I am facing a persistent issue where Abaqus 2024 does not detect the Intel Fortran compiler, even though I have installed the Intel oneAPI HPC Toolkit and integration with Visual Studio 2022.
Problem messages:
When launching Abaqus 2024 with a user subroutine, I get:
WARNING: vars.bat does not set up dependencies when invoked directly.
Please perform environment setup for UMP before running DPC++ applications.
after adding call "C:\Program Files (x86)\Intel\oneAPI\setvars.bat" intel64 vs2022 i am able to remove warning shown above but still not able to run Fortran.
Unable to find a Fortran compiler on this system. If Intel Fortran is installed on this system, please load ifortvars.bat before running Abaqus."
What I have tried:
  1. Verified Fortran works in Intel command prompt.
  2.  ifortvars.bat is nowhere to find.
  3. Tested both ifort and ifx. by changing win64_env file
  4. Checked abaqus_v6.env but not sure of correct syntax for oneAPI + VS 2022.
  5. call "C:\Program Files (x86)\Intel\oneAPI\compiler\2025.2\env\vars.bat" intel64 vs2022
  6. call "C:\Program Files (x86)\Intel\oneAPI\setvars.bat" intel64 vs2022
I tried all the methods from youtube and forums but it is still not working for me. Kindly help.
andrew_4619
Oneapi 2025 does not have ifort it only has the newer IFX. Free Ifort downloads are no longer available. IFX can be configured try a forum search this topic is frequent or go to an abacus forum .
