Abaqus 6.11 subroutine
Shuai_Hou
Dear all,
I want to link Intel Fortran to Abaqus 6.11 and download a 30days fortran 12.1 evaluation version. However, when i run cmd, it always show an error like:
standardU.dll.manifest : general error c1010070: Failed to load and parse the manifest. The system cannot find the file specified.
Abaqus Error: Problem during linking - Abaqus/Standard User Subroutines.
This error may be due to a mismatch in the Abaqus user subroutine arguments.
These arguments sometimes change from release to release, so user subroutines
used with a previous release of Abaqus may need to be adjusted.
Exception: (, LinkError('Abaqus/Standard User Subroutines',), )
File "SMAPyaModules/SMAPyaDriver.mpy/Lib/driverAnalysis.py", line 181, in run
File "SMAPyaModules/SMAPyaDriver.mpy/Lib/driverStandard.py", line 64, in analyze
File "SMAPyaModules/SMAPyaDriver.mpy/Lib/driverSharedLibrary.py", line 180, in run
File "SMAPyaModules/SMAPyaDriver.mpy/Lib/driverSharedLibrary.py", line 325, in link
LinkError: Abaqus/Standard User Subroutines
Abaqus/Analysis exited with errors
I have checked from google but still cannt solve it. Abaqus verification sent me a warning shows that:
Requirement: Intel Fortran Compiler 10.1 or 11.1
Product: Abaqus make utility with Fortran and Abaqus with user
subroutines
Status: Warning - Found Intel Fortran Compiler 12.1, which is newer
than the published Abaqus requirement at the time this
version was released. Later minor releases of a published
requirement are generally compatible with Abaqus. Please
check the system requirements web page for the latest
information on supported configurations.
So i am thinking is it the version 12.1 too new for Abaqus 6.11 and where can i get i Fortran 11? Thanks a lot.
Adam
Steven_L_Intel1
The error you saw has nothing to do with the compiler version. I suggest that you contact Abaqus support for help with this.
Gerhard_Prechtl
Dear Shuai Hou,
I have got the same problem and it would be interesting if you have a solution?
Thanks for your answer.
Gerhard
TimP
instructions on how to install older compilers are posted at the top of the forum. The instructions which come with your version of Abaqus would tell you which major versions of ifort were tested with that Abaqus build.
