29276 Discussions
About DFORRT.dll's abort message!
brb36641
Hi, I have one issue regarding DFORRT.dll abort message in DOS prompt.
When exe type program which is written as follows has run under DOS prompt, I get above mess.
Sorce code summerly
program main-routine
inquire('same-file',exist=yes)
if (YES) stop
write(*,*) 'Test Program'
stop
end
If same-file is exit under working folder, this program running will normal stop, I think, However sometile I get abort message of this.
Should I change the cord as follows,
if (yes) goto 10
10 stop
end
How is my idea? Is it correct under specification of Fortran laungage?
Let me know, please.
Steven_L_Intel1
What is the exact abort message you get? I don't completely understand your question.
STOP is not a good thing to use, especially if you may want to change your program into a DLL in the future. I suggest a GOTO to the END statement.
brb36641
Thank you.
It is good suggestion for me to use GOTO the END statement.
Meanwhile what kind situation should I use STOP statement?
Steven_L_Intel1
I would not use it at all in programs I wrote. But it is certainly convenient in places where you just want to exit the program in case of an error. It is a very old feature of the language.
brb36641
I see it is old style to use STOP statement, when I stop the programs.
Thank you for kindness. Is that programiing style 80's?
I am clear and finish to solve my issue.
