29277 Discussions
Accessing Paths found in the Registry
brian_hanley
I'm new to Intel FORTRAN (using 9.1). Is there a way to access paths found in the Windows registry? Asimple call would be great :-)...sorry if this is a no brainer
Jugoslav_Dujic
Valued Contributor II
Yes, either USE IFWIN, and use the functions outlined here (at the minimum you need RegOpenKeyEx, RegCloseKey, RegQueryValueEx and RegSetValueEx), or use the attached wrappers I wrote (which simplify the calls, allow Fortran-style strings to be used, etc.). The documentation for the wrappers can be found in the .chm file here, while sample usage is here.
brian_hanley
Thank you, Mr. Dujic :-)
