Actual and dummy procedure argument mismatch - Error 7062
ivanpribec
Hello fellow Fortranners,For two evenings I have been struggling to debug the following error:
/home/ipribec/nlopt/test/t_modern_fortran.f90(215): error #7062: The characteristics of dummy argument 2 of the associated actual procedure differ from the characteristics of dummy argument 2 of the dummy procedure.   [MSQUARE]
        call myopt%set_min_objective(msquare,f_data,ires)
According to other posts (see here) I could find on the forum, this error shows up when the INTENT descriptors (or other characteristics) of the actual and dummy argument do not match. Now for a bit more background on my specific problem.
I am writing a Fortran wrapper for the nonlinear optimization package NLopt written in C. Like in the C++ wrapper I am aiming for an object-oriented API, that behind the scene makes calls to the individual C routines using the iso_c_binding module for interfacing. Ideally, the application developer in Fortran would be completely free from the iso_c_binding module. For passing functions I have came up with two different options, one is a "functor" pattern where the user must extend an abstract type with a deferred function argument (any parameters can be stored in the derived type), and the other is to pass a function that accepts an extended type in case any parameters are needed by the function (this approach is used in the Fortran interface to the GNU Scientific library - FGSL). Both solutions are a bit verbose, but are meant to guarantee type safety.
A shortened version of the wrapper module is shown below:
module nlopt
    use, intrinsic :: iso_c_binding
    use nlopt_c_interface ! the C binding is stored here
    ! ... imports from a few other modules ...
    implicit none
    private
    ! ... bunch of public statements ...
    ! Exposed for the user to extend!
    type, abstract, public :: nlopt_void
    end type
    public :: user_func_interface
    abstract interface
        real(c_double) function user_func_interface(n,x,grad,data)
            import c_int, c_double, nlopt_void
            integer(c_int), intent(in), value :: n
            real(c_double), intent(in) :: x(n)
            real(c_double), intent(out), optional :: grad(n)
            class(nlopt_void) :: data
        end function
    end interface
    ! ... other type declarations ...
    type, public :: opt
        private
        type(c_ptr) :: o = c_null_ptr ! the "nlopt_opt" object on the C side
        integer(c_int) :: last_result = NLOPT_FAILURE
        real(c_double) :: last_optf = huge(1._c_double)
        integer(c_int) :: forced_stop_reason = NLOPT_FORCED_STOP
        type(adaptor), pointer :: objective => null() ! keep handle to objective function on Fortran side
        ! ... other stuff for book-keeping the constraints ...
    contains
        procedure, private :: set_min_objective_oo
        procedure, private :: set_min_objective_new
        generic, public :: set_min_objective => set_min_objective_oo, &
        ! ... other functions and subroutines defined by the C API ...
    end type
contains
    subroutine set_min_objective_new(this,user_func,user_func_data,ires)
        class(opt), intent(inout) :: this
        procedure(user_func_interface) :: user_func
        class(nlopt_void), target :: user_func_data
        integer(c_int), intent(out), optional :: ires
        integer(c_int) :: ret
        type(c_ptr) :: c_handle
        type(c_funptr) :: c_fun_handle
        if (associated(this%objective_handle)) then
            nullify(this%objective_handle)
        end if
        allocate(this%objective_handle)
        this%objective_handle%func => user_func
        this%objective_handle%data => user_func_data
        c_handle = c_loc(this%objective_handle)
        c_fun_handle = c_funloc(nlopt_function_poly_c)
        ret = nlopt_set_min_objective(this%o,c_fun_handle,c_handle) ! C function call
        if (present(ires)) ires = ret
    end subroutine
    ! ... all the other type-bound procedure  ...
end module
What I am using here is an adaptor pattern, where the user function and parameters are passed to the C function as a void* along with an adaptor function "nlopt_function_poly_c" that then evaluates the user function with the passed data. This way the user need not worry about making the calls to c_loc and c_funloc himself.
A simple driver program then looks something like this:
module new_mod
    use, intrinsic :: iso_c_binding, only: c_int, c_double
    use nlopt, only: nlopt_void, user_func_interface
    implicit none
    private
    public :: msquare
    type, extends(nlopt_void), public :: my_void
       ! any data needed to parametrize the user function
    end type
contains
    real(c_double) function msquare(n,x,grad,data)
    implicit none
        select type(data)
            class is (my_void)
                if (present(grad)) then
                    grad(1) = 0.0_c_double
                    grad(2) = 0.5_c_double/sqrt(x(2))
                end if
                msquare = sqrt(x(2))
            class default
                stop "[msquare] incorrect extension of nlopt_void"
        end select
    end function
end module
program main
    use iso_c_binding
    use nlopt, only: algorithm_name, nlopt_version, opt, nlopt_void
    use nlopt_enum, only : NLOPT_LD_MMA
    use new_mod
    implicit none
    call new_example
contains
    subroutine new_example()
        use nlopt, only: user_func_interface
        implicit none
        integer(c_int), parameter :: n = 2
        procedure(user_func_interface), pointer :: p_msquare => msquare
        type(opt) :: myopt
        ! ... other declarations ...
        type(my_void) :: f_data
        print *, "========= NEW EXAMPLE =========="
        myopt = opt(a=NLOPT_LD_MMA,n=n)
        call myopt%set_min_objective(msquare,f_data,ires) ! does not work
        !call myopt%set_min_objective(p_msquare,f_data,ires) ! works
       ! ... rest of the program ...
    end subroutine
end program
If I compile the code with the Intel Fortran Compiler (Version 19.0.1.144) I get the error shown at the beginning. Surprisingly, if instead of passing the function I pass a pointer to the function (p_msquare), and "force" the routine to comply with the required interface, then the program works. The gfortran/gcc compiler is also able to compile the example normally.
My confusion goes even further, when I tried create a minimal working example that would reproduce this error, the code compiled just fine! The minimal example:
module test_mod
    implicit none
    public :: nlopt_void, nlopt_opt
    type, abstract :: nlopt_void
    end type
    abstract interface
        end function
    end interface
    type nlopt_opt
    contains
        procedure, public :: set_objective
        procedure, public :: set_min_objective_new
        generic, public :: set_min_objective => set_min_objective_new
    end type
contains
    subroutine set_objective(this,func,func_data)
        class(nlopt_opt), intent(inout) :: this
        procedure(user_func_interface) :: func
        class(nlopt_void), target :: func_data
        integer(c_int), parameter :: n = 5
        real(c_double) :: x(n)
        x = [1.,2.,3.,4.,5.]
        print *, func(n,x,data=func_data)
    end subroutine
        ! implicit none
        print *, "hello"
    end subroutine
end module
module func_mod
    use iso_c_binding
    use test_mod, only: nlopt_void
    implicit none
    private
    public :: msquare
        ! real(c_double) :: a,b,c
    end type
contains
        select type(data)
            class is (my_void)
            end if
            class default
        end select
    end function
end module
program test_mod_main
    use, intrinsic :: iso_c_binding, only: c_double
    use test_mod
    use func_mod, only: msquare, my_void
    implicit none
    type(nlopt_opt) :: opt
    type(my_void) :: my_func_data
    ! my_func_data = my_void(1.,2.,3.)
    call opt%set_objective(my_func,my_func_data) ! works
    call opt%set_min_objective(msquare,my_func_data) ! works
contains
    real(c_double) function my_func(n,x,grad,data)
        my_func = sum(x)
    end function
end program
In case you would like to test it, the entire code can be found on the "simple" branch of my fork of NLopt. To compile with Intel Fortran it is necessary to  uncomment the lines 21, 22, and 234 in CMake file and choose the correct the directory address of the ifort and icc compilers. I can also upload the entire source code if needed.
I would be grateful for any ideas on what is causing this error to show up, even if the interfaces seem to be correct (after all gfortran compiles normally and just by passing a procedure pointer instead of the function makes the program work!?).
Best,
Ivan
Juergen_R_R
Valued Contributor II
It would be nice to include the actual module with the bind C definitions that one needs to compile the first example. I think you should also make user_func_interface a bind(C) routine. I think in our code we are always using these kinds of things as procedure pointers.
ivanpribec
As far as I can remember the user_func_interface cannot have the bind(C) attribute since it takes a non-interoperable argument of class(nlopt_void). But indeed the ifort compiler required the bind(C) attribute for the function nlopt_function_poly_c used in the type-bound procedure set_min_objective_new that actually gets called in the C code. (gfortran was able to compile even without it)
I will attach the actual modules as soon as possible.
FortranFan
This looks like a bug in Intel Fortran compiler especially considering your attempt at a minimal working example, which closely your actual case, works.  You may want to submit a support request at Intel Online Center (OSC) with your full example as the case: https://supporttickets.intel.com/?lang=en-US
ivanpribec
The modules and test example are in the attached tar archive.
My compilation steps and output:
00:04:48 ipribec@ThinkPad: ~/nlopt/mwe$ ifort -c nlopt_enum.f90 nlopt_c_interface.f90 nlopt.f90 t_modern_fortran.f90
t_modern_fortran.f90(215): error #7063: The characteristics of dummy argument 3 of the associated actual procedure differ from the characteristics of dummy argument 3 of the dummy procedure.   [MSQUARE]
compilation aborted for t_modern_fortran.f90 (code 1)
00:05:01 ipribec@ThinkPad: ~/nlopt/mwe$ nano t_modern_fortran.f90  # replace msquare with p_msquare in line 215
00:05:25 ipribec@ThinkPad: ~/nlopt/mwe$ ifort -c t_modern_fortran.f90
To create an executable than requires linking against the NLopt library in C (https://github.com/stevengj/nlopt).
The minimal working example I tried creating to isolate the error:
00:08:19 ipribec@ThinkPad: ~/nlopt/mwe$ ifort minimal_example.f90
00:15:55 ipribec@ThinkPad: ~/nlopt/mwe$ ./a.out
   15.0000000000000
 hello
I will look into submitting a support request. Thank you.
mecej4
Before filing a bug report, please consider the following errors/extensions in the code that you posted as an attachment to #5.
1. An argument to a BIND(C) procedure should not be OPTIONAL (several places).
2. You have used the function NLOPT_GET_DIMENSION in several specification expressions.
ivanpribec
Thank you mecej4 for these concerns.
Regarding point #1 I thought this is allowed according to the Fortran 2018 standard? In section 21.2 Optional arguments (page 397) in the chapter "Fortran 2018 enhancements to interoperability with C" of Modern Fortran Explained, 2nd edition, Metcalf, Reid, and Cohen (2018) it says "... Fortran 2018 adopts this idiom for permitting Fortran interoperable procedures to have optional arguments. ... In a call from Fortran, when the actual argument is absent, a null pointer will be passed to the C procedure." This is exactly what I need, because for minimization algorithms that do not require the gradient calculation, a null pointer will be passed instead.
Regarding point #2, I do not think this is a violation as the procedure NLOPT_GET_DIMENSION is declared pure. I have committed however a minor crime here as I know this procedure is pure only from inspecting the C code and not because the Fortran compiler could inspect the body of this function. A perhaps safer solution would be for me to store a copy of the integer dimension variable in my derived type OPT. In the C++ wrapper they have made use of exceptions to warn the user to initialize the OPT instance, before allowing any objective or constraint functions to be specified.
mecej4
I see your standpoint, but the 19.0.2 compiler does not seem to accept it yet:
$ ifort -stand -warn stderrors -c nlopt_c_interface.f90
nlopt_c_interface.f90(9): error #8809: An OPTIONAL or EXTERNAL dummy argument to a BIND(C) procedure is not interoperable.   [GRADIENT]
        real(c_double) function nlopt_func(n,x,gradient,func_data) bind(c)
nlopt_c_interface.f90(17): error #8809: An OPTIONAL or EXTERNAL dummy argument to a BIND(C) procedure is not interoperable.   [GRADIENT]
        subroutine nlopt_mfunc(m,result,n,x,gradient,func_data) bind(c)
compilation aborted for nlopt_c_interface.f90 (code 1)
NOTE: One of the delightful features of the forum software is that you have to copy/paste the lines with "error #8809" into an editor before you can see something meaningful. Sorry!
ivanpribec
I see. With the 19.01 compiler and flag "-warn all" these errors are not displayed and the code ends up working like it's supposed to (besides from the error 7062), as far as I've tested.
Juergen_R_R
mecej4, the ifort option -stand without any argument according to the help menu specificies the standard as f08, so indeed the optional argument should be flagged as an error. -stand f18 should let it pass.
jimdempseyatthecove
As a separate issue, I happen to have noticed this in post #1:
        end if
The above implies a memory leak should this%objective_handle be associated to begin with. Assuming the handle hadn;t been deallocated elsewhere.
Jim Dempsey
mecej4
Thanks, Juergen. You are correct on both points. However, did IvanP specify -stand f18 (or equivalent), or any option related to language version, when he compiled and ran his tests?
ivanpribec
Thank you Jim for this observation. I had the feeling a deallocation statement was missing.
In fact there are other memory leaks I am aware of. The problem is that I am passing Fortran routines for the objective functions and minimization constraints to the C side. If I do not keep a handle on the Fortran side, I am risking a memory leak if the user decides to specify a different objective function or remove the constraints and apply new ones, because the C routines that perform this cleanup cannot deallocate the memory allocated on the Fortran side. My planned solution is to maintain a linked list of the constraint functions in the Fortran object with a finalizer routine, that will deallocate any memory, before calling the original C routine. This is my first project building a C wrapper from Fortran and I've learned a lot :)
Juergen_R_R
I think he didn't specify such a flag, and according to him he didn't see the error message. ifort as a default should accept all implemented features from the newest published standard, when I remember correctly.
ivanpribec
mecej4 wrote:
I can answer this point instead. Indeed, I was not specifying any particular language standard and just running with the defaults. I will add these points to my documentation, that the code assumes a Fortran 2018 compliant compiler.
EDIT: Juergen was faster to answer.
ivanpribec
I filed a support request for this issue.
The next compiler update release (out in 3 to 6 weeks) seems to fix the interface issue and compile my example without errors.
