29250 Discussions
Adding Leading Zeroes to a Character String
Ernie_P_1
I'm converting some old Fortran code and need toadd some leading zeroes to a character string. What I need to accomplish is:
I always need my numer(1-999) to have 3 character digits.
1 should be 001
50 should be 050
999 should be 999
My old code had the following internal write:
write(charNUM,"(B'###')")NUM
IVF doesn't allow this. My solution was to do the following:
IF(NUM.LT.10)THEN
WRITE(CHARNUM,'(I3)')NUM
CHARNUM='00'//TRIM(ADJUSTL(CHARNUM))
ELSE IF(NUM.LT.100)THEN
CHARNUM='0'//TRIM(ADJUSTL(CHARNUM))
END IF
There must be a cleaner solution than this. Any thoughts?
Ernie P.
Steven_L_Intel1
WRITE (charNUM,'(I3.3)') NUM
Steven_L_Intel1
Ernie_P_1
Wow that was simple.
Thanks, Steve.
Steven_L_Intel1
... and standard conforming, unlike whatever it was you were using (never saw that extension before.)
