I'm converting some old Fortran code and need toadd some leading zeroes to a character string. What I need to accomplish is:
I always need my numer(1-999) to have 3 character digits.
1 should be 001
50 should be 050
999 should be 999
My old code had the following internal write:
write(charNUM,"(B'###')")NUM
IVF doesn't allow this. My solution was to do the following:
IF(NUM.LT.10)THEN
WRITE(CHARNUM,'(I3)')NUM
CHARNUM='00'//TRIM(ADJUSTL(CHARNUM))
ELSE IF(NUM.LT.100)THEN
CHARNUM='0'//TRIM(ADJUSTL(CHARNUM))
END IF
There must be a cleaner solution than this. Any thoughts?
Ernie P.
1 should be 001
50 should be 050
999 should be 999
IF(NUM.LT.10)THEN
END IF
Ernie P.
WRITE (charNUM,'(I3.3)') NUM
... and standard conforming, unlike whatever it was you were using (never saw that extension before.)
