After 2020 update 1: missing integration in MS VS 2019
Erik_T_1
After updating to Parallel Studio XE 2020 update 1 (from 2020)  i have no integration in Visual Studio 2019 anymore. I can't create new fortran projects (they ar nowhere to be seen (in the create new project dialog)) and VS cannot load already existing projects. I get the following error from Visual Studio 2019 version 16.5.4 when I try to reload a fortran project:
Unsupported
This version of Visual Studio is unable to open the following projects. The project types may not be installed or this version of Visual Studio may not support them.
For more information on enabling these project types or otherwise migrating your assets, please see the details in the "Migration Report" displayed after clicking OK.
     - MyFortranProject, "C:\Users\me\source\repos\MySolution\MyFortranProject\MyFortranProject.vfproj"
Non-functional changes required
Visual Studio will automatically make non-functional changes to the following projects in order to enable them to open in Visual Studio 2015, Visual Studio 2013, Visual Studio 2012, and Visual Studio 2010 SP1. Project behavior will not be impacted.
     - MySolution, "C:\Users\me\source\repos\MySolution\MySolution.sln"
I have tried to "Repair" installation both with the 2020 (no update) installation file as well as with the 2020 update 1 installation file.
Steve_Lionel
I had this problem - solved it with an uninstall of Intel Parallel Studio 2020 and then a reinstall.
Steve_Lionel
JohnNichols
Valued Contributor III
I found that update 1 took 4 days to install -- it kept starting and stopping -- do as suggested it usually works
Erik_T_1
Thanks Steve, that worked!
JohnNichols
JohnNichols
I thought something was funny when the update 1 installer kept coming back, but I was looking at the program listing and there are two update 1 with different version numbers, anyone know what is happening?
Barbara_P_Intel
John, PSXE 2020 Update 1 for Windows when it first appeared on March 30, 2020, had a problem than made installation super slow. A new download replaced that one on April 2, 2020.
Hence,
  • March 30 --  2020.1.085
  • April 2 --  2020.1.086
The rest of the content remains the same, only the installer changed.  So, if you have 2020.1.085, there is no need to download again.
Thanks to Ron for doing the sleuthing!
JohnNichols
Barbara:  The automatic installer started trying to run after 085 was installed as I had done the install manually -- I could not understand why the installer kept starting and stopping over about 4 days -- finally it installed
It was when I was looking at programs I noticed I had 3 versions, original 085 and 086.
I was also interested on whether Intel had updated Fortran for the changes in the VS 2019 Preview 16.6, so I tried and yes you have fixed so latest Fortran runs with the preview.
